low vacuum at idle, a tuning issue?
Old Aug 16, 2009 | 01:26 PM
haysoos's Avatar
Car: 89 GTA
I have a base timing of 6 deg and the car is running smoothly. my vacuum reads around 7-10 hg at idle, but jumps up to the 20s when revved up. I have a "mild cam" -could this cause my low vacuum? Also my brakes hardly work. I have sprayed the engine compartment entirely with B12 and cannot find any leaks in the new mini-ram.
Can these vacuum issues be changed by tuning/bin editing my timing on my MAF setup?
What values would affect the vacuum pressure?
Old Aug 16, 2009 | 01:57 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: low vacuum at idle, a tuning issue?
a cam can definatly affect your vaccum....one route you could go is to pick up a vaccum resivior and that will store any un used vaccum and you should be ok but just MHO
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
jklein337
Sep 19, 2018 06:23 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
