Lunati 50161
Old Aug 25, 2009 | 07:40 PM
Seanmay1's Avatar
Car: 89 Firbird Formula WS6
Engine: TPI 305
Transmission: T 5
Axle/Gears: 3.45 Posi 9 bolt
Lunati 50161
Would this cam do good in a 305? Going to be switching to HSR pretty soon and adding headers. I know i will have to tune the car also
Which valve springs would work?
Old Aug 27, 2009 | 06:21 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
Re: Lunati 50161
duration seems way too high for a 305 car and the setup your using and you can also go a lil higher on the lift too... i say its a bad match..
Old Aug 27, 2009 | 07:37 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
Re: Lunati 50161
i thought u couldnt go over .480 lift with stock heads
I talked to lunati, and they told me the best cam for me would be a 54743, he said i could use the 54761 but it wouldnt make any power until 2500rpm but would make more power up top though
Old Aug 27, 2009 | 07:56 PM
88fastgta's Avatar
Re: Lunati 50161
oh your running stock l89 heads... yeah that cam is way too much cam for the stockers... even tho the lift is ok the duration with those lb9 heads is whats going to kill your setup.. your heads will not support those rpms and even so you might have valve float if your running press in studs and stock springs and such.. im using stock modified iron l98 with screw in studs on my gm hotcam with 1.5 rockers its 218/228 492 492 lift.... my heads are really killing my setup and im leaving alot of horsepower on the table..... i didnt have the money to buy new heads but i will be fixing that soon with afr 180s.... maybe some other guys with hsr's will help because im running a highflow tpi..
Old Aug 27, 2009 | 09:13 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Re: Lunati 50161
Too much duration. Try again.
Old Aug 27, 2009 | 09:43 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
Re: Lunati 50161
well if i cant get a nice idle im not gonna spend the money i will just do 1.6 rockers and continue to hate how the car sounds
Old Aug 27, 2009 | 10:03 PM
88fastgta's Avatar
Re: Lunati 50161
im pretty sure mnorton has a nice idle... he has the crane 2032 cam... i used to have that cam in my old l98 setup also its a 214/220 452/465 lift 112lsa..... that is the max you can use without doin any work to your heads... here is a link of how my car sounded with that cam... you dont need a big crazy cam like the one you mentioned for it to sound nice or off idle....just curious, why would you want a hsr on a 305 anyways... the tpi on a 305 isnt the bottleneck at all....
http://www.youtube.com/watch?v=YmAOj...e=channel_page
http://www.youtube.com/watch?v=Yja12...eature=channel
and thats on a 350 so i imagine it should sound a bit more choppy with a 305.... that cam would be MUCH better with your goals... use 1.5 rockers with this cam... 1.6 rockers will cause issue with stock unmodded heads..
Old Aug 27, 2009 | 10:31 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
Re: Lunati 50161
That sounds a lot better than mine, maybe i will go ahead with a cam swap. But im getting all the things i can use for a 350 when i get the cash to build the motor i want. But until then i just have to get more out of this motor, i spend a lot more time at higher rpms so i figured the HSR would do better than the TPI. Right now it pulls pretty good to 4800 drops a little but still pulls to 5500 but thats it.
Old Aug 27, 2009 | 10:47 PM
88fastgta's Avatar
Re: Lunati 50161
well with the hsr on a 305 your torque will go way down... and it will feel like a pig around town...... thats why i was wondering why u wanted to swap... just port the tpi or get big tube runners and edelbrock lower intake.. trust me you will be much happier with that and the crane 2032 cam... that setup will get you to 5500 easy on a 305... then you can swap all that to a 350... i have a 355 tpi look at my mods.... my car is really really run to drive as an everyday driver...
Old Aug 27, 2009 | 10:55 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
Re: Lunati 50161
for some reason i can't find that cam on summit, lol 20 min ride and im at the summit store though i love it lol. I will look into the runners also
Old Aug 27, 2009 | 11:33 PM
88fastgta's Avatar
Re: Lunati 50161
the part number is 104224...... thats right crane cams went out of business..so you have to look on ebay for one... its a great cam and its made for tpi cars... its considered the biggest cam for stock heads and computer... here is a new one on ebay which is a good price for it actually
http://cgi.ebay.com/ebaymotors/Crane...Q5fAccessories
i tried looking at online retailers and they no longer carry it cause they went out of business..
add that cam along with some slp runners and port plenum and stock intake with stocks heads cold air intake and maybe 22lbs injector and afpr and you will be very happy and a smile on your face when you hear the car idle.... it will make for a very fun daily driver that should easily rev to 5500 rpms.. im assuming thats your goal for the car... i see you already have some nice mods done already.....
Old Aug 28, 2009 | 12:52 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
Re: Lunati 50161
yes this is my daily and yep that sounds about right. Depending on what my check looks like today i might go ahead and pick that cam up off ebay.
Old Aug 28, 2009 | 01:02 PM
Justinlf16's Avatar
working on 89 camaro
it had a tbi 305 im putting a built 350 in it, anyways i thought it had a turbo 350 but came to figure it had a 700r4 how hard is it to put a turbo 350 in there am i gonna need anything special like lines or anything? thanks justin
Old Aug 28, 2009 | 01:14 PM
88fastgta's Avatar
Re: working on 89 camaro
idk anything about swapping different trannies try posting this on the transmission/drivetraind board... this is the tpi board....
Old Aug 28, 2009 | 01:31 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: Lunati 50161
I had that crane compucam in my 88 IROC it had a 350 in it, the cam sounded very healthy and definitely woke the car up, with a stock TPI even. Had a TON of low end grunt.
Old Aug 28, 2009 | 07:05 PM
88fastgta's Avatar
Re: Lunati 50161
yeah get that cam..... you wont be disappointed.... to me horsepower numbers mean nothing to me anymore... as long as its fun as hell to drive to you thats all that matters....
Old Aug 28, 2009 | 08:59 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
Re: Lunati 50161
well it wont be this week but the 2032 it is
john204481
Sep 7, 2015 03:22 PM
ede
Aug 10, 2001 07:17 AM
Camarogofast
Feb 26, 2001 04:06 PM
Ace_Murdock
Aftermarket Product Review
Dec 19, 2000 09:29 PM
