camshaft ideas 327 .40 over w/ tpi
so i'm building a motor for my truck and i have a tpi setup (MAF). the block is a 327 .40 over with 194 heads. i don't know exactly what type of camshaft i should be looking into but i know that i need to have a cam that will perform correctly with the EFI. So my question is, what is the most radical cam setup I can go with?
Guest
Posts: n/a
Re: camshaft ideas 327 .40 over w/ tpi
Depends on your tuning skills. I would not go past 215ish on the intake duration with stock programming, and probably the heads wont do a whole lot of good past that anyway, depending on what exactly may have been done to them if anything at all.
well, i have stock programming now, but i am going to have it rechipped after i rebuild this motor. i was just wondering what my best option will be.
Pac J
05-17-2020 10:44 AM
88SS6SPEED
11-11-2015 07:05 AM
