350 carb to lb9 tpi swap
Old Aug 31, 2009 | 04:22 PM
chrisjj1989's Avatar
Car: 1990 camaro rs
Engine: 355
Transmission: th350
Axle/Gears: 3:73
i currently have a 1972 350 4 bolt bored .40 over in my 1990 camaro with a carb. i have reently accuired an lb9 engine from a transam. i was wondering what i would have to do to put the upper end onto my 350 block. i want to get rid of the carb and i have the computer and wires 4 the lb9. would i be shooting my self in the foot putting this injection system on to my 350 block?
Old Sep 5, 2009 | 08:48 AM
Vader's Avatar
Re: 350 carb to lb9 tpi swap
If you install 22-24PPH injectors, your result will be a L98 with more cubes. Torque and fuel efficiency should improve. Starting should be more consistent.
The 1990 body should have (or should have had) most of the necessary wiring in place. You will need a fuel pump delivering 43 PSI, hoses to connect the lines to the fuel rails, and a fuel return line to the tank. You will need an inline fuel filter. An ECM will have to be installed. You will need the later style distributor, detonation sensor, O² sensor in the exhaust, and would probably benefit from electric fans. Almost everything else you will need should be attached to the intake and plenum.
You will also need to consider the transmission, since an auto may need a TCC lockup signal and have a 4th gear switch to be connected to the ECM.
Old Sep 9, 2009 | 11:57 AM
Car: 1990 camaro rs
Engine: 355
Transmission: th350
Axle/Gears: 3:73
wouldnt i need to have the computer reporgramed for the new injectors?
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
