400 injector size
Old Sep 7, 2009 | 09:29 PM
1BAD89's Avatar
400 injector size
im gona bolt my tpi injection onto a motorha that has around 400-450hp and was wonderin what size injectors should be used for this and if thier is any other modifications i should do befor bolting this on?
Old Sep 8, 2009 | 12:39 AM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Re: 400 injector size
More info on the motor would be nice, heads, cam etc etc, also that 400-450hp was probably with a carb, a stock TPI is going to choke that motor up alot. Also plan to have a chip burned ASAP or that thing is going to run like crap. Your probably better off getting a carb setup, it would be alot easier and youll make more power.
Old Sep 8, 2009 | 01:33 PM
1BAD89's Avatar
i would have to look at the motor to tell you more it is a carb set up right now and the cam if i remember right is like 550 lift or so and mabe around 250-280 duration i think, dont know for sure.
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
bamaboy0323
Sep 3, 2015 06:07 AM
knight72
Aug 10, 2015 09:32 PM
