Injector Help / Black Ford injectors?
Old Sep 9, 2009 | 11:03 AM
lthrneck's Avatar
Car: 89 Iroc
Axle/Gears: 3.70 9bolt
Hey guys need a little help. I can get a complete set of injectors from a 2005 Mustang Saleen for 60 bucks but the numbers do not cross to anything that I know will work for sure. My car is in Texas so I can not walk out and look to check the connections to ensure they will work. I appreciate the help. The injectors are solid black with the following numbers.
4L8E-A4A
9F593 244
5076D05378
Old Sep 9, 2009 | 11:59 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: Injector Help / Black Ford injectors?
They appear to be 24lb, EV6 injectors.
You will have to retune the pcm, get a harness adapter. you also cannot use the clips to keep them in the fuel rail, they will just "lay" in it.
Old Sep 10, 2009 | 06:38 AM
lthrneck's Avatar
Car: 89 Iroc
Thanks Dale,
I was thinking they did not have the correct ends for my harness. I have no desire to start putting in extra wires and adpaters so I will find another set. Thanks aagain.
69 Six Pack
Oct 5, 2015 07:51 PM
New2Chevy
Oct 4, 2015 11:27 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Jae992
Aug 27, 2015 09:07 AM
tmellott89
Aug 16, 2015 02:58 PM
