any thoughts on this problem
Old Sep 10, 2009 | 10:35 AM
cutlassman14's Avatar
Car: 90 trans am
Transmission: 5 spd
where to start,ive been having a really hard time starting the bird lately,at first it seemed like it wasnt firing on all 8, so i went and bought a new Distributor for it, well that didnt do anything for it,first fire up with it, it spit and sputtered then flood it self out again, i pulled the vac off the reg to see if any fuel was in the vac line, there wasnt. it throw a code 43 and 53,any help would be great as im at my wits end with this damn thing almost ready to part this thing out
Old Sep 10, 2009 | 11:30 AM
racethesunlive's Avatar
Car: '92 Camaro
Re: any thoughts on this problem
43 is your knock sensor or ECM, If you disconnect the connector to reset base timing (single connector on the left by the blower motor) does the engine seem to run more smoothly? Also try pulling one of your spark plugs and checking it for signs of bad ignition timing.
Old Sep 10, 2009 | 12:06 PM
Car: 90 trans am
Transmission: 5 spd
pulled a plug motor is differently flooding it self,
Old Sep 10, 2009 | 12:29 PM
Car: '92 Camaro
Code 43 could be putting the motor in "limp home" mode where the timing is set way back and fuel gets pumped in. Did you try replacing your knock sensor to see if you could clear the SES light? and did disconnecting the base timing connector help at all?
Old Sep 10, 2009 | 05:44 PM
Car: 90 trans am
Transmission: 5 spd
havent tried replacing the knock sensor yet,but will as i pulled a couple plugs to find them soaked with gas,so i guess another set will be going in( which sucks as these 1's are lucky to have 20 kms on them) i do have spark,that ive checked,but would the knock sensor make it flood it self out? this tpi stuff is new to me,car ran awsome until this happened and which it happened all of a sudden without warning
Old Sep 10, 2009 | 07:26 PM
Car: 90 trans am
Transmission: 5 spd
thought id add, i just finished checking all the injectors, all but 1 were 17, the other 1 was 10
Old Sep 10, 2009 | 07:55 PM
witnlyn's Avatar
Car: 54 Chevy Sedan Delivery
Axle/Gears: 3.73 posi
I had a bad coolant temp sensor that made mine flood . try pulling fuel pump fuse to clear out the fuel. test cts with ohm meter.
Old Sep 10, 2009 | 08:19 PM
Car: 90 trans am
Transmission: 5 spd
ohm'd cts is it was 3.14 ohms, not sure if thats good or not, also i cant start it right now as it wont start yet, but did check tps also, its right where it should be,
Old Sep 10, 2009 | 08:40 PM
witnlyn's Avatar
It depends on the engine temp check this page out see if it helps you. When mine was bad I had no reading at all. http://www.kemparts.com/TechTalk/tt13.asp
Old Sep 10, 2009 | 08:46 PM
Car: 90 trans am
Transmission: 5 spd
thanks for the link,car hasnt run since this morn,id like to think its cold now....lol im a carb guy whos making the switch to tpi, but sure isnt liking it.....lol, oh ya when i retrieve the codes with the jumper,my fan didnt come on,but instead heard what sounded like clicking noises
Old Sep 11, 2009 | 05:02 PM
witnlyn's Avatar
An other possibility is your map sensor.
Old Sep 11, 2009 | 05:52 PM
Car: 90 trans am
Transmission: 5 spd
just wish i knew,getting tired of changing the plugs,where the fuse for the fuel pump located
Old Sep 11, 2009 | 06:06 PM
witnlyn's Avatar
It might have a inline fuse you could pull the relay also not sure where it is I have an aftermarket wire harness. look by mastercylinder on firewall
Old Sep 11, 2009 | 06:32 PM
witnlyn's Avatar
pulling relay will stop fuel pump from running with key on but when oil presure comes up pump will start to run after that, to disable fuel pump all together you might have to un plug it at the tank.
Old Sep 12, 2009 | 11:10 AM
Car: 90 trans am
Transmission: 5 spd
well after changing the plugs again, fig id try and start it again,as soon as it starts it starts to flood it self,i unplugged the fuel pump, and get it started and runs great,plug it back in and floods,would the knock sensor or cts cause that,havent tried the map sensor yet but do have spare 1's, what happens if i were to just unhook the knock sensor?
Old Sep 12, 2009 | 12:41 PM
Car: 90 trans am
Transmission: 5 spd
changed the cts, wasn't
that
Old Sep 12, 2009 | 01:45 PM
witnlyn's Avatar
My understanding is the knock sensor adjust the timing for pinging.
Old Sep 12, 2009 | 01:48 PM
witnlyn's Avatar
did you clear the codes?
Old Sep 12, 2009 | 01:50 PM
Car: 90 trans am
Transmission: 5 spd
sure did,but still getting the same codes,if i want the car to idle, i have to unhook fuel pump wire if not still flooding out,i did pull puter out,its got a hypertech chip, part number 120353,not sure cant figure it out soon its going carbed
Old Sep 12, 2009 | 02:08 PM
witnlyn's Avatar
Do you have a code list , here is a link to gm codes
http://www.troublecodes.net/GM/90-91_50F.shtml
Old Sep 12, 2009 | 02:10 PM
Car: 90 trans am
Transmission: 5 spd
thanks,this thing is driving me nuts,stupid part about it,was it was running great with no problems, then went to leave work and bam, nothing but problems
Old Sep 12, 2009 | 02:14 PM
witnlyn's Avatar
code 53 battery volt high , maybe battery over charging, shot in the dark? could be ECm like racethesunlive said earlier.
Old Sep 12, 2009 | 02:15 PM
Car: 90 trans am
Transmission: 5 spd
just want this thing to run.....lol, running out of ideas to look at
Old Sep 16, 2009 | 05:55 AM
witnlyn's Avatar
Any luck yet?
Old Sep 16, 2009 | 08:34 AM
Car: 90 trans am
Transmission: 5 spd
well ive changed every senor but 1,( 1 on the passenger side head,looks like a temp sensor)still flooding, thought for sure fuel pressure reg,just tested it and its at 42 psi,mind u it only ran for 5 seconds, but it held at 42,still have the gauge hooked up and timing the leak down
Old Sep 16, 2009 | 09:17 AM
Car: 90 trans am
Transmission: 5 spd
after 45 mins pressure is at roughly 34-35 sitting not running
Old Sep 16, 2009 | 11:21 AM
86camaroZ's Avatar
Car: 86 iroc
Engine: 350 vortec HSR
Axle/Gears: 370
check...all...your...vacuum...lines...idk these cars are ridiculous at times. Good Luck!
Old Sep 16, 2009 | 05:24 PM
Car: 90 trans am
Transmission: 5 spd
after over 7 hours fuel pressure is sitting at 15 on the gauge
Old Sep 16, 2009 | 05:40 PM
witnlyn's Avatar
You said you change all sensor but 1. there is a sensor under plenum for mat did you get that 1 as well. it is the same part as cts.
Old Sep 16, 2009 | 05:42 PM
Car: 90 trans am
Transmission: 5 spd
no i didnt,i just got the plenum off
Old Sep 16, 2009 | 05:48 PM
witnlyn's Avatar
try pluging in your old cts to it and see if that does it, whats your battery volts?
Old Sep 16, 2009 | 05:49 PM
Car: 90 trans am
Transmission: 5 spd
fully charged,its got me,
witnlyn's Avatar
still same codes?
Old Sep 16, 2009 | 05:52 PM
Car: 90 trans am
Transmission: 5 spd
ya,i got it going in to be put on a scanner,hope it finds something i cant
Old Sep 17, 2009 | 05:56 PM
witnlyn's Avatar
check out this thread it has alot of info about a problem like yours.
https://www.thirdgen.org/forums/tech...ml#post4285364
Old Sep 17, 2009 | 06:53 PM
Car: 90 trans am
Transmission: 5 spd
true we both seem to be having the problems,but mine floods all 8 on start up,even after 30 plus hours i still got 10 psi on my fuel gauge from starting it yesterday
Old Sep 17, 2009 | 07:18 PM
witnlyn's Avatar
any luck with scaner?
Old Sep 17, 2009 | 07:31 PM
Car: 90 trans am
Transmission: 5 spd
gos in tomorrow afternoon,new gaskets for intake,runners and TB came in tonight,but working midnights,so im gonna put it back together tomorrow morn and then take it in
i shot this 2 weeks before all this happened,
http://www.youtube.com/watch?v=fX3ORY2d_cc
1 thing i did do was pulled the fuse from my daytime running lights,and while doing that i noticed my fog light fuse was missing,so i put a fuse in it,i dont think the 2 are connected by any means
Old Sep 17, 2009 | 07:37 PM
witnlyn's Avatar
did you check pulse on your injector wires when cranking just to see how often the fire?
Old Sep 17, 2009 | 07:38 PM
Car: 90 trans am
Transmission: 5 spd
no can say i didnt do that
Old Sep 17, 2009 | 07:42 PM
witnlyn's Avatar
test light between the two wires when cranking it should strobe. not shure how fast just neat to watch.
  #42
Car: 90 trans am
Transmission: 5 spd
i will test that
Old Sep 18, 2009 | 11:40 AM
  #43
Car: 90 trans am
Transmission: 5 spd
heres what ive changed today, fuel pressure reg,(tho the old 1 looked ok no rips or nothing) adjustable 1 will be in on monday so just got the baffle rebuild kit for now, knock sensor,air temp thingy under plenum,thermostat,intake and plenum gaskets,map sensor,tps only 1 i didnt change was the iac sensor,fig id wait to see what happens with the scan today, i got my fingers crossed but no faith in it.....lol
1 thing i did noticed was the new fuel pressure baffle was at least 1/16th to a 1/8th taller then the old 1,
Old Sep 18, 2009 | 02:21 PM
  #44
Car: 90 trans am
Transmission: 5 spd
well still doing it,puffing black smoke huge on start up with fuel pump hooked up,runs ok with out it hooked,my temp right now is roughly 125, tested my cts, volts was .51 and ohms was .48,
Old Sep 18, 2009 | 05:00 PM
  #45
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Why didn't you change your injectors while you had the intake apart to change the fpr. you did say that one of them ohm'd out at 10 right? That right there can cause a whole mess of problems.
Old Sep 18, 2009 | 05:02 PM
  #46
Car: 90 trans am
Transmission: 5 spd
when i retested it,they were all the same hot and cold,plus the leak down test woulda showed if 1 was bad,and its like what 15 mins tops to take it apart again
Old Sep 18, 2009 | 05:17 PM
  #47
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
I would start to suspect that hypertech chip too possibly. Do you have the stock one around anywhere to try and see if it helps? Check grounds...especially the one for your computer as well.
Old Sep 18, 2009 | 05:22 PM
  #48
Car: 90 trans am
Transmission: 5 spd
no i wish i did thou,gonna start on the grounds,garage didnt have time for my car today for the scan,only codes im getting still is 53 and 43
Old Sep 18, 2009 | 05:35 PM
  #49
Car: 90 trans am
Transmission: 5 spd
begining to think plug wires even thou they are brand new, but just cheapys when i was timing it,i had a hard time getting it to light the timing light,would work here and there
Old Sep 19, 2009 | 01:21 AM
  #50
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Holding the pedal to the floorboard before cranking disables the injectors to clear the flood.
