solid lifter cam
Old Sep 10, 2009 | 05:08 PM
89lt1's Avatar
Car: 1989 firebird formula, 1991 z/28
Engine: none LSX! one day, 350tpi
Transmission: none t56 one day, t5
Axle/Gears: 9-bolt 3.45, 10 bolt 3.73
solid lifter cam
can you run a solid flat tappet cam in a tpi or will it mess with the knock sensor
Old Sep 10, 2009 | 06:40 PM
BadSS's Avatar
Re: solid lifter cam
I'vr had no problems with knock retard running solid cams. However, I typically run tight lash type cams and use a little teflon tape on the sensor and install it no tighter than necessary to prevent a coolant leak.
Jorlain
Oct 8, 2015 01:57 AM
Stryker412
Sep 7, 2015 09:11 AM
dimented24x7
Sep 6, 2015 03:51 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
