Highest RPM Possible
Old Sep 10, 2009 | 09:11 PM
DerfPower509's Avatar
Car: 84 Z28 and a 95 Z28
Engine: Built 350 sixty over
Transmission: W/C T-5
Axle/Gears: 4:56s auburn posi, mosers, girdle
I was just curious what is the highest RPM that anybody has ever turned and still made power with a tuned port? The only stock parts im planning on using are the lower and upper plenum and they will be ported. Would appreciate any answers you might have thanks.
Old Sep 11, 2009 | 06:15 AM
BadSS's Avatar
Re: Highest RPM Possible
I fully ported (full length - not siamesed) the stock base and plenum and hogged out a set of SLPs best I could without cutting and welding. It would run the same ETs shifting at 5300 as it would at 5700, but ET and power dropped off REALLY fast past that point. You want to build around the shift recovery point with these TPIs to make sure you're catching some of the torque boost from the runners when you shift into 2nd gear. You have to run a decent set of heads, a good exhaust system, and a cam with at least 218 intake duration to do that.
Old Sep 12, 2009 | 12:20 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
My 1-2 shift was around 5,850-5,900 on the STOCK runners and plenum feeding my 350 TPI Vortec in my Van. The power was definately still hanging in there at 6K as it would pull right up to redline and actually bang off the rev-limiter for a second or so before the trans could complete the shift. 2-3 happened around 5,500, STUPID SLIPPING 700r4 was on its LAST leg. I raised the rev-limit to 6,500 in the ECM and just let the transmission slip during the shifts. The transmission DIED shortly after that, but the TPI didn't mind reving out to 6,250 before the 700r4 could catch 2nd.
Rebuilt 4L60E with Transgo HD2 shift kit and stock converter.. 1-2 and 2-3 upshifts right at 5,500 in the PCM programming. Nice tight shifts.
Elephantismo
Feb 13, 2019 12:51 AM
PurelyPMD
May 5, 2016 04:57 PM
Damon
Sep 26, 2015 04:29 PM
wisemanz28
Sep 20, 2015 01:26 PM
