need help asap
Old Sep 13, 2009 | 11:47 AM
Gta27's Avatar
need help asap
i have a 1991 trans am gta 5.7 and when i put it in gear it wont go past 3000 rpm please help asap
Old Sep 13, 2009 | 01:14 PM
Jaydog143's Avatar
Car: 1989 Iroc-z
Engine: 5.7L 350
Axle/Gears: Stock 2.77 posi
Re: need help asap
do you have a msd ignition box on the car?
Old Sep 13, 2009 | 04:48 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
Re: need help asap
could be fuel pump breaking down.
Old Sep 14, 2009 | 07:10 PM
Gta27's Avatar
Re: need help asap
no i do not have an msd ignition box on it just got it so its stock except for flowmasters
Old Sep 16, 2009 | 09:17 PM
soxbaseball's Avatar
Re: need help asap
will it go over 3000 when its in park and neutral?
Old Sep 16, 2009 | 11:56 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: need help asap
does it shift b4 3K? or shift early? any surging or hesitation?
Old Sep 17, 2009 | 07:06 PM
Gta27's Avatar
Re: need help asap
it will go over 3000rpm when in park and neutral if i try to take off it willgo up to 3000 and start sputering then i let of the gas and it shifts
Old Sep 18, 2009 | 08:59 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Re: need help asap
does it easily go up to redline in park/neutral or does it hesitate just at a higher rpm?
92GTA
Apr 9, 2016 07:39 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Brother Al
Oct 14, 2015 06:39 AM
92projectcamaro
Sep 24, 2015 08:09 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
