How do i adjust the timing when...
Old Sep 17, 2009 | 09:27 AM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
The timing gauge or mark whatever it's called is missing from my car. I put a new distributor in because the pick up blew apart on the old one. I set the new dist. about where the original one was and tweeked it one way or the other little by little until it ran the best, but now the car is throwing a code 15 which i don't think has anything to do with the timing,(it's for the coolant temp sens.).
also the car starts up and idles ok but as soon as i give it any gas it stalls.
any help is appreciated. thanks.
Old Sep 20, 2009 | 05:32 PM
trueburton's Avatar
Re: How do i adjust the timing when...
any help?
Old Sep 22, 2009 | 11:32 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
You should be able to buy a new timing tang at auto zone or pepboys, look in the engine dress-up section, it bolts in place using the timing cover bolts.
Old Sep 22, 2009 | 12:30 PM
trueburton's Avatar
thanks i'll give that a try
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 21, 2015 07:20 PM
86White_T/A305
Aug 17, 2015 12:16 AM
