? About TPS Adjustment Procedure found on this site
Old Sep 20, 2009 | 11:16 AM
Slowridr's Avatar
Car: 1987 GTA Vert & 1991 GTA 5 Speed
Engine: 87 GTA-L98 91 GTA LB9
Transmission: GTA-700R4 & GTA T5
Here it is https://www.thirdgen.org/tpimod2
Does the IAC need adjusting when installing a new TPS?
What is best and most importantly easiest to use when adjusting the TPS, Scanner or VOM and Jumper Wires?
I dont have a VOM or Scanner so if I am going to buy something what should I buy. I dont plan on selling the car so if I will be using this in the future I might as well go ahead and get something that can be useful for other maintenance and repairs.
So please make any and all suggestions on best to buy for this procedure and most useful in my future maintenance.
Any more hints and advice on this procedure would be appreciated as well for IAC adjustment.
Old Sep 20, 2009 | 11:22 AM
Slowridr's Avatar
Re: ? About TPS Adjustment Procedure found on this site
Question about IAC
What is drivability like when IAC is out of adjustment.
Well let me go ahead and ask too.........
What is drivability like when TPS is vaulty and/or out of adjustment. When a TPS goes bad is it a slow and erratice failure or is it a case of it either works or it doesnt?
Old Sep 20, 2009 | 01:15 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
the TPS is seperate from the iac. but it is imperitive that the tps in correct. you need a cheep vom.. 9 bucks at radio shack. adjust it to .54 volts at idle... car off key on. term c is the 5 vlt reference a and b are the ground and out put.. WOT should be 5 volts less initial. so .54 idle, the tps should read 4.5 at WOT.. the iac has an adjustment on the pintle.. set it at 28mm from the flange and reinstall it. make sure the small air passage is clean and open.
Old Sep 21, 2009 | 05:55 PM
witnlyn's Avatar
Car: 54 Chevy Sedan Delivery
Axle/Gears: 3.73 posi
In regards to tps adjustment, is there a different ohm setting for maf and sd systems?
Old Sep 22, 2009 | 10:40 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
No but on the later cars there is no TPS adjustment; the computer takes the inital Volts as the base.
Old Sep 23, 2009 | 05:36 PM
witnlyn's Avatar
Found this so I was curious what was right.
http://www.iroczone.com/techarttpsadj.html
Old Sep 23, 2009 | 09:07 PM
Slowridr's Avatar
Nice, Very nice.
Old Sep 23, 2009 | 09:10 PM
Slowridr's Avatar
I havent bought the Voltmeter yet and havent checked my TPS but my car was stumbling bad tonite so I just unhooked my TPS. I am now going to drive the car and see if it will not stumble/sputter/cough/spit etc, etc, etc.
I am about tired of this!
Old Sep 23, 2009 | 09:47 PM
Slowridr's Avatar
Just drove the thing hard. The harder I pushed it the worse the sputtering got.
WOT it would pull good then fall back like it wasnt getting fuel, then I let off the gas it would pull some like I was giving it more pedal!
As I gave it gas and let off it would pull/fallback (WOT), Pull (let off throttle only slightly).
Finally it got to where it wouldnt pull well even from a Stop sign so I shut the car off and crank it back up (while in nuetral) and BAM!!! it ran just fine until I pushed it again.
Drove it on home and now it sits. I still have some patience left but my tank is getting low with this one.
I guess its not the TPS huh.
Ill still check it anyway.
86IROC112
Aug 21, 2015 07:20 PM
86IROC112
Aug 21, 2015 12:39 PM
perZ
Aug 15, 2015 01:17 PM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
