Walbro Install - Retain Foam Sleeve?
Old Sep 22, 2009 | 01:32 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
I am putting an LS1 in my car, so I bought my self a Walbro fuel pump due to the higher pressure required (GSS340 is the part number) Anyways the old pump had a foam sleeve on it, and the new pump didn't come with one. When I removed the old sleeve I accidently ripped it and can't reuse it now on the new pump. Do the Walbro or other aftermarket pump even require this? I am assuming it is for cooling when the fuel level gets low or something like that. Any help is greatly appreciated!
Old Sep 22, 2009 | 02:23 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Re: Walbro Install - Retain Foam Sleeve?
My LT1 car comes with the Walbro style pump...I replaced it with one anyway recently, and I did not need the foam or anything...didn't even have it I don't think. it doesn't sound familiar anyway. I have driven the car to near empty and full with no issues so far, so I believe you will be ok.
Old Sep 22, 2009 | 10:59 PM
Shift06's Avatar
Thanks! If anyone else has any personal experiences though also it'd be much appreciated.
Old Sep 23, 2009 | 04:26 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I always thought it was for noise reduction.
I re-used mine.
Old Sep 23, 2009 | 07:24 AM
Car: '87 Trans-Am
Yea, noise reduction would be its purpose...and if the fuel has ever sat for a while or been old at any point in the cars life, those sleeves tend to be all but falling apart.
Old Sep 23, 2009 | 01:27 PM
Shift06's Avatar
Ah perfect. I'll leave it off then. I prefer a whiney fuel pump anyways lol.
Old Sep 24, 2009 | 02:34 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
When I changed my fuel pump on my 87, I don't recall there being a sleeve on the pump. I replaced it with with a Walbro (because I started running nitrous) and it also did not come with a sleeve. Car has been fine this whole time...
Old Oct 4, 2009 | 02:38 PM
RADs Racer's Avatar
Why take anyone's word for it? Just call Walbro.
Are you sure you have a GENUINE Walbro? There are a lot of knockoff's out there from CHINA. They are real crap!
Vintageracer
Jan 10, 2020 05:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
red90IROCls1
Aug 25, 2015 06:56 AM
