AFPR 86 IROC
AFPR 86 IROC
I just installed a BBK AFPR in my Camaro. Before I installed the AFPR the stock fuel pressure (with the vacuum line to the AFPR disconnected) was 42 psi. After the install I raised the psi to 52. I haven't really noticed a difference so I am wondering if I should try raising the psi some more or if the AFPR just doesn't add noticeable horsepower?
Re: AFPR 86 IROC
Unless you want to wear out the Fuel pump with the higher PSI, I would keep it at 45. you are not going to feel that SOTP performance. I added fuel pressure gage just to check the PSI's.
Re: AFPR 86 IROC
How does the AFPR affect the fuel pump? All the AFPR does is allow you to compress the internal spring inside the housing to increase fuel pressure to the injectors. The computer will then adjust the band width of the injectors. The whole benefit to the AFPR is it creates better fuel atomization.
Re: AFPR 86 IROC
Re: AFPR 86 IROC
Yea but the fuel pressure increases because that internal spring is compressed not because the fuel pump is sending more fuel, right? Sorry, I don't mean to argue I'm just trying to figure things out.....
Car: 1989 IROC-Z
Transmission: Th700R4
Re: AFPR 86 IROC
Highering the PSI at the rail, will higher the pressure/load on the pump
The stock pump is not built to work above 50PSI for longer periods of times.
If you want higher PSI then 50 you need a new pump, Walbro 255 HP pump (rated60+) can deliver it for you.
But going higher then 50PSI isnt needed on a pretty much stock engine..
Car: 1989 IROC-Z
Re: AFPR 86 IROC
IAC is Idle Air Control
There is only an advantage to change it if its bad..
I thought mine was bad so I changed it when I cleaned out the whole Throttle Body.. It had 20 years on it , so I thought a new Delco one would be good..
Re: AFPR 86 IROC
I thought you would know the IAC contolls the Idle Air and turns it into working air in the thottle body. Best reason to replace the IAC is to get that air working again and not letting it be Idle.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: AFPR 86 IROC
A regular old CPI Astro pump works for me and I run 50 PSI constantly on LT1 injectors.
Car: 1989 IROC-Z
Re: AFPR 86 IROC
Fast355: I know
thats why I wrote that he only needs it if he wants pressure over 50psi and that a pretty much stock car runs fine on the old pump and pressure
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
Re: AFPR 86 IROC
if you are going to go through the trouble of replacing the pump, why put a lesser unit in? if you slap in a walbro you have a higher quality unit and if you decide to add no2 or a turbo in the future you won't have to buy another pump.
a good psi to run with these engines(especially mostly stock) is around 46. good atomization and it doesn't put too much stress on a stock pump
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
mustangman65_79
Aug 11, 2015 03:17 PM
