Not what I expected
Old Sep 24, 2009 | 01:25 PM
patrick92z28's Avatar
Car: 1992 Z28
Engine: 6.0
Transmission: 4L80E
Not what I expected
I have recently built a new motor for my 92 Z and now that it is done I am severly dissapointed. The car does not run well at all! Sometimes it surges sometimes not and there is a serious lack of power. I have been trying to access the ecm to no avail with a couple different scan tools and software but they all say no ecm data. I have been able to retrieve codes by useing the jumper but the ecm does not flash anything except code 12 unless I do something to make it like unplug a sensor. I have gone through all my grounds and ohmed every wire on the ecm connectors. I have also replaced tps, all temp sensors, o2 sensor, oil pressure, knock sensor and the egr valve. Could the ads chip which was in the car when I bought it cause this problem? I read that with the speed density systems you have to reprogram the chip to get them to run well but I can't even access the ecm to see what it is doing and I thought the motor would at least as good as the old 181000 mile motor did! I have added afr 180 heads, zz4 cam, tpis bigmouth manifold, hooker headers, ported the plenum, and bosch III #22 injectors. Any advice would be greatly appreciated as I am out of ideas.
ZZ3Astro
Aug 13, 2019 12:57 AM
86z89iroc
Oct 5, 2015 01:04 PM
hartsmike
Oct 2, 2015 07:11 AM
80smetalfan
Sep 22, 2015 02:55 PM
BWilcox
Sep 20, 2015 12:19 PM
