194 heads/mounting problems
Old Oct 7, 2009 | 02:12 PM
benin360's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: stock
i got some fulley 194 heads. everything is good except my old heads have all the mounting holes for like my power steering pump, alt,..... ya. is there something i can buy? or do i need to make the brackets? drill holes?
Old Oct 7, 2009 | 06:29 PM
benin360's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: stock
Re: 194 heads/mounting problems
come on guys. some help please? i need it put back togeather by next tuesday.
Old Oct 8, 2009 | 04:58 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Are you saying that the 194 heads don't have any of the mounting holes drilled and tapped for your accessories????
Did you check both ends of the heads for the needed mounting holes?
I've never seen a pair of SB Chevy heads that didn't have mounting holes. However, if the heads don't have ANY mounting holes and you want to keep all the same accessories, you're going to need a machine shop to properly position and drill/tap the needed holes. Care is needed not to drill into the water jackets or ports.
If they have a couple of holes, but just not the ones you need, then you may be able to find the brackets used for those heads from the factory which probably use holes in the block.
I don't know of any other way.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
