intake manifold removal problems
Old Oct 12, 2009 | 01:40 AM
ffemtm70's Avatar
Car: primered 1987 IROC-Z/28
Engine: 305 TPI HO
Axle/Gears: Lotsa slip 3.23
Hi all...I am trying to get the intake manifold off but the stupid torx bolts are seized. It is just two of them right at the front of the manifold. I sheared off one T45 already and twisted the other one. Any suggestions. It has been soaking in WD40 for a day and still won't budge. I am getting ready to just drill them out but I wanted to salvage them so I can include them with the manifold when I go to sell it.
Old Oct 12, 2009 | 05:40 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: intake manifold removal problems
PB Blaster kicks the crap out of WD-40.
Kroil kicks the crap out of PB Blaster.
Couple any of them with an impact wrench and you should be golden.
Old Oct 12, 2009 | 07:58 AM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
wd 40 will not break those loose.. no way, use Kroil
Old Oct 12, 2009 | 10:54 AM
ffemtm70's Avatar
Engine: 305 TPI HO
Cool thanks
Old Oct 13, 2009 | 02:57 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
be careful. Ruin the part, break your wallet. VIse grips were used on my intake plenum torx bolts seized
Old Oct 13, 2009 | 03:01 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Buy a torx bit that's meant to be used with air tools. They're made from harder steel, and don't twist/shear so easily. Also, they might actually be T47, it's an oddball torx size that only GM seems to use.
Old Oct 13, 2009 | 08:28 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
also take a steel rod place on/or into the Bolt head and Give it a med tap with a Hammer.. this should work..always Make sure it's the right size.
tool.. even if it's a ford tool.
Jake_92RS
Jan 28, 2020 10:37 PM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
3rdgenparts
Aug 8, 2015 07:09 PM
