lt1 cam help
Old Oct 16, 2009 | 12:09 AM
phoenixxx602's Avatar
Car: 1986 z28
Axle/Gears: 3:73
lt1 cam help
ok im new to THIS thirdgen site and i read all about the BANNED post and i didnt see this question in here so i hope im not braking the rules! if i put lt1 cam in 89 lb9 without a chip or tune will it still run good?
Old Oct 16, 2009 | 02:41 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Re: lt1 cam help
I actually have the LT1 cam in my LB9, but it hasn't run in this car yet so I don't know for sure. However, the guy I bought the engine from (good friend and GM parts counter guy so I trust his judgement) said it ran very well in his '91 T/A.
Old Oct 16, 2009 | 08:29 AM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
Re: lt1 cam help
The lt1 cam is not that much different from the L98 cam which could have come in the LB9 aswell. With your car being a MAf car I think you should be ok. Once you really start changing things you will need a chip but a cam this mild I would think yo uare ok.
Old Oct 16, 2009 | 12:10 PM
Car: 1986 z28
Axle/Gears: 3:73
Re: lt1 cam help
ok thanx... this third gen site is way better than the one i was on b4!! what about the lt4 cam? how much diffrent is it from the lt1 cam?
Old Oct 16, 2009 | 03:12 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Re: lt1 cam help
The LT1 cam with will run good with no changes to the chip needed. It's an easy swap in that will give you a solid 25 to 30 rearwheel horsepower and wake up that 305.
The LT4 hot cam is aggresive and would require you to change the valve springs in the head and require custom programming.
Old Oct 16, 2009 | 04:19 PM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
Re: lt1 cam help
i went from the stock lt1 cam in my 96 to the complete lt4 kit with the hotcam and 1.6 rockers(rockers are part of the kit-i think that the lift and duration figures stated for the hotcam are based on 1.6 rockers) and the hotcam is a pretty big step up compared to the stock cam. required a complete tune of the pcm to be drivable. awesome power increase though.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
L0tuS
Sep 4, 2015 11:16 PM
Strick1
Sep 4, 2015 07:11 AM
