Firebird intake suxs
Old Oct 25, 2009 | 05:26 PM
gofastbird's Avatar
I have a k&n drop in filter on my firebird other than sound i dont think it is doing much improvement since it is still sucking up hot air...slp dicontinued intake, and i cant seam to find one that is worth anything...Also cant find much when i SEARCH either. Does anyone kno of anything that can be bought or know how to fab a custom one?? Thanx
Old Oct 25, 2009 | 06:42 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Firebird intake suxs
TBI or TPI
Old Oct 25, 2009 | 06:46 PM
gofastbird's Avatar
Old Oct 25, 2009 | 07:00 PM
89RS_82Z's Avatar
ok so you got the tube that hooks to the throtle body and goes to the filter box, that is actually a pretty good set up, i know this prob aint the answer you are looking for but look in the tech mods section on the home page, that page is actually very helpful
Old Oct 25, 2009 | 07:09 PM
gofastbird's Avatar
thanx man just what i was looking for i have never even been on that tech page just found a new friend lol
Old Oct 26, 2009 | 04:46 PM
jack harrison's Avatar
Car: 1987 pontiac trans-am
Engine: 350 tpi
Axle/Gears: 3;73 with eaton lsd
have you re-routed the coolant hose that goes through the trottle body? that'll cool down the incoming air considerably. also, have you fitted an air foil in the throttle body. these along with the K&N will help.
Old Oct 26, 2009 | 08:11 PM
Drew's Avatar
SLP's answer was a very cheap injection molded box sealed to the inner fender, and the exact same ducting you have now. It's barely an improvement over the stock setup.
There aren't a bunch of aftermarket cold air intakes for these cars, because the stock setups are pretty damn good. Chances are your stock setup isn't limiting performance as much as you think it is.
1992 Trans Am
May 10, 2023 07:19 PM
masonta
Aug 31, 2015 10:14 PM
theshackle
Aug 22, 2015 06:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
