Injector problem
Old Oct 25, 2009 | 07:03 PM
wannaz's Avatar
Car: 90 iroc z
Engine: 350 needs work
Transmission: 700r4 needs work
Injector problem
Ihave one injector not working. I ohmed the injectors and had 14.7 to 14.9. I bought this car with motor problems and upon removing heads this cylinder never fired since rebuild. Piston looked new. I have replaced heads cam pushrods and rockers. With the engine back in now it runs rough. I do have spark in this cylinder. Just no gas. Since this injector ohmed good could it just need cleaned?
Old Oct 26, 2009 | 12:25 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Injector problem
it could be a wiring problem or the injector may be stuck closed.
to check the wiring, use a noid light to see if the ECM is firing the injector. if it isn't, check the power to it with a test light.
if you have power, open the harness up and check the ground side of the
wiring.
if its stuck, sometimes cleaning them will help.
but if they are the factory multec injectors, it would be best to just replace
the complete set with the bosch 3s.
for the price of 2 stock replacements, you can get a full set of bosch injectors.
southbay08 is a site sponsor and sells injectors,
http://www.southbayfuelinjectors.com/
you can also get them from FIC,
http://fuelinjectorconnection.com/shop/
bryan623
Mar 22, 2021 06:43 PM
Street Lethal
Apr 30, 2019 12:14 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
tmellott89
Aug 16, 2015 02:58 PM
