Thinking About Custom Air Intake...
Old Nov 5, 2009 | 08:21 PM
NJP93's Avatar
Car: 1989 Trans Am
Well I'm looking to make some more power for my 350, and I'm thinking about making a custom air intake out of stainless tubing and a simple cone air filter. I've searched this board a lot, but I can't find anything about the MAF sensor in the stock plastic intake tubing. Do you guys just eliminate it somehow or is there a simple way to mount it into a custom air intake?
Old Nov 6, 2009 | 10:38 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Thinking About Custom Air Intake...
theres a few threads about modifying the maf. I've seen some one make a 4in maf using a stock 3rd gen one. Also some people just get a 4th gen LS1 maf and just get a maf translator and install that, but the most common swap is going to SD (speed density) which eliminates the maf altogether...
Old Nov 16, 2009 | 08:59 PM
Dr. Z's Avatar
Car: 91' Camro Z28
Engine: 5.0 TPI
stainless steel istn't what you want to use, it retains heat! If you are going to do it you should use thin gauge aluminum.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
midge54
Jan 29, 2017 07:00 PM
mdtoren
Aug 23, 2015 12:52 PM
kah992
Aug 19, 2015 02:55 PM
mdtoren
Aug 16, 2015 05:45 PM
