Cam swap thought
Old Nov 6, 2009 | 12:12 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Cam swap thought
I am curious if the lifter retainers will hold the lifters in place on a Gen 1 engine to swap the cam.
I have done a few cam swaps on Gen 3 engines and you don't have to pull the lifters out because the lifter retainers hold them in place. I have done Gen 1 flat tappet cam swaps and obviously pulled the lifters. I haven't done a roller cam in a Gen 1 though.
I may try it anyway since I have to pull the oil pan to replace the gasket.
Anyone try it before?
Old Nov 6, 2009 | 01:19 PM
Drew's Avatar
Re: Cam swap thought
They dont work that way... You can actually buy LS style holders for 1G roller cam blocks from GM, so they will, but they didnt exist until a few years ago.
Edit: GM calls them "quick cam" valve lifter guides... Part number 88958652. There's one in each package, so you need two to complete an engine. List price is about $20. FWIW.
Old Nov 6, 2009 | 03:45 PM
Basically I'm trying to get away with swapping the cam without removing the intake. I don't care about using the stock spider/dogbone setup, I just dont feel like spending the time removing and installing the TPI if I don't have to.
Old Nov 6, 2009 | 06:42 PM
Drew's Avatar
You're screwed with the stock setup. You've gotta pull the intake, spider, lifter keepers, and lifters. Or else they'll fall as soon as you start moving the cam.
You can get the parts so that next time you won't have to, but this time around you're out of luck.
midge54
Dec 27, 2019 04:14 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
