code 33 MAF defective
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Hi guys, need some help here. I just got my IROC running (other than the slipping tranny). While the Camaro was idling, I had no Check Engine light. So I dumped in some Lucas Transmission additive to get the tranny from slipping. So after all said and done, I took the Camaro out for a drive. The tranny would stay stuck in 1st until I floored it. Then the tranny went into gear (above 1st). But as I floored it, the Check engine light came on. Now as Im getting ready to stop at the stop sign, the Camaro sputters and then dies. I turn it on and it still sputters. Eventually, it'll stop sputtering and will run right. So what can be the issue to the sputtering and the Code 33 pop up? I recently replaced the FPR and the whole guts of the distributer.
BumpaD82
Feb 26, 2016 02:57 PM
