South Bay Injectors
Old Nov 20, 2009 | 05:18 PM
cwv2's Avatar
Car: 1991 Chevrolet Camaro Z28
Engine: T.P.I. 305
Transmission: 700 R4
Axle/Gears: Richmond 3.73
South Bay Injectors
I recently purchased a set of injectors from South Bay Fuel Injectors. I have heard many opinions on the Bosch III injectors with the spacer installed on them. I can tell you from experience that these injectors are top notch. The fitment of these injectors are perfect. The new spacer does not leak and the throttle response with the new injectors is incredibly better than stock. The injectors were about 160.00 bucks. A great deal if you compare them with the price of the new ones. These injectors have a three year unlimited mile warranty. If you were to get a bad injector I am sure that something would go wrong within the time of warranty.
If you are concerned about the spacer to make the Bosch injectors for into the TPI fuel rail and intake; don't be. The spacer can in no way affect the performance of the injector. I have heard comments that spacer may retain heat. That is not possible due to the fact that, the coil inside the injector is not located in the same area as the metal spacer.
Also the spacer does not affect the flow pattern because, it does not interfere with the direction of spray.
I hope that this clears up any issues that anyone has with the whole injector dilemma. I am not saying that these injectors are as good as new. But, I am saying that i found them to be a great product at an affordable price.
Old Nov 20, 2009 | 08:29 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Re: South Bay Injectors
Thanks i will get some
86CamaroDan
Sep 29, 2015 10:08 PM
webeeZ28
Sep 14, 2015 12:00 PM
earlpote
Sep 12, 2015 11:55 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Keiffer76
Sep 9, 2015 08:52 PM
