TPI Throttle response Help?
Old Nov 25, 2009 | 10:08 PM
Siggy's Avatar
Car: 1988 Camaro IROC LB9 F
Engine: 305 HO EFI
Transmission: TH700R4
Axle/Gears: GU5 LS 3.23
I have a 1988, Camaro IROC LB9 Auto, Fitted with K&N filers and removed intake screens to improve flow, no AIR, enrichment injector or EGR and use a ARAP bin.
I am quite pleased with the drive and mileage (23-26 mpg), however the throttle response (in drive) is very sharp and sudden off idle...almost as if the torque converter had early lockup..more like a switch was thrown, not very progressive.
The 700R4 transmission does have a leaking (morning sickness) front seal, however even with fluid top up the response is the same. I'm not sure if I have a throttle or transmission problem.
Old Nov 26, 2009 | 10:57 AM
jack harrison's Avatar
Car: 1987 pontiac trans-am
Engine: 350 tpi
Axle/Gears: 3;73 with eaton lsd
Re: TPI Throttle response Help?
is this a sudden proplam or has it always done it? sounds like typical fuel injected V8 response to me!!
Old Nov 27, 2009 | 01:25 AM
Siggy's Avatar
Engine: 305 HO EFI
Typical..I'm not sure. The long story is I had an engine fire 3 days after purchase. During the insurance repairs I had the shop remove the AIR and when I got it back I removed the EGR and added the K&N filters, learn about the EFI & computer, got some Moats gear and installed a ARAP eprom.
The sharp response could well be normal as all other engine behavior is great. I was very careful with throttle plate setting, throttle pot and cables. At 72 yrs my feet lack a bit of touch..tends to move in 1/4" jumps, so it may be I just live with it...
92camaroJoe
Jul 29, 2023 07:57 PM
fonzie85
Aug 13, 2015 11:50 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
