Performance camshaft with stock heads??
I was hoping to get some advice with getting a new camshaft. I am rebuilding a 305 (first engine rebuild please don't give me static for not going with the 350) and I would like to put in a better camshaft. I would like to get one for some more low end torque.
I was thinking some thing with a 220 duration, 110 degree lobe separation ( I got those from reading on the internet). Now I am using the same heads, so I was hoping you guys could give me some suggestions.
Here are a few of my choices
http://www.streetperformance.com/par...702.html#d3702
http://www.streetperformance.com/par...ml#dCL12-230-2
http://www.streetperformance.com/par...85-100032.html
Please let me know what you guys think, or if I am in the wrong ball field let me know. And remember stock heads!!
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Performance camshaft with stock heads??
Those are all pretty good choices for low end grunt but all appear to be flat tappets cams. If your engine is an 87 and newer, it will have roller lifters. You can run a flat tappet but you ll need to change the style timing set you have, which is a good idea anyway. IMHO, however, you leave power on the table with a flat tappet cam versus a roller cam of same specs due to reduced friction and the quicker ramp rates of a roller. Just my 2 cents.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
topher1316
'87 and up motors were roller blocks. So you'll need a roller cam. 305 TPI cam specs for automatic cars are 179/194 350/348 109
I'm doing a cam swap in my 89 305 TPI. I've decided just to swap in a used LT1 cam (cost $20-30). The specs are 203/208 460/460 116. It's a good inexpensive little upgrade and LT1 cams can be found everywhere.
Just remember to change your springs, locs and retainers.
I recommend the ZZ4 springs - part number 12495494
Locks part number - 12495503
Retainer part number - 19171528
Go to www.gmpartsdirect.com
They seem to have cheap pricing for GM part numbers. Changing the springs, lock and retainers is cheap insurance.
Good luck.
Good luck.
Car: 87 Suburban 2500
Engine: 455 Wildcat ( somewhat modified ))
Transmission: TH400 ( for now )
Axle/Gears: 4.10 ( for now )
The boys at Comp Cams are real good.
It was a pleasant surprise, and a mild disappointment what I asked them for their recomendation for my project.
I gave them all my specs, and intended use., wanted performance, "settle for" performance, and such, and they recommended EXACTLY the cam I already have ! ( one of theirs )
Since they do this every day, AND made a recomendation that lost them a sale, I'm impressed !
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
What year 305 do you have? some had the L98 cam which aint much smaller than the LT1. Infact it had more duration but less lift. You can get similar lift with 1.6-1.65 Rockers.
220 degrees is abit much for a 305 TPI car.
I'd probably go for a 212/218 cam or similar. ZZ4 aint bad either and can be had for cheap. Most cams will require you to have heads machined to accept higher lift. doesnt cost all that much
Car: 89 IROC
I have a brand new ZZ4 cam at home to be installed later
Car: 89 Iroc-z
Transmission: TH400
ZZ4 cam will definitely need screw in studs installed and machine work done. By the time you do all that to stock heads might as well save for some TFS heads. Many threads here about running ZZ4 cams in 305 motors.....good performance for the buck
The smaller 175cc heads for smaller bore motors can be used on a 355 later and make great power so its not a purchase just for a 305, its an investment for possible future engine build for more power Re: Performance camshaft with stock heads??
Wow, thanks guys. That is exactly the information that I needed. You have convinced me from buying an aftermarket cam to buying an LT1 cam, and saving maybe a hundred bucks. And I will probably get the aluminum drive shaft after I rebuild the engine.
Thanks every body.
Chris
Thanks every body.
Chris
theshackle
Mar 5, 2017 06:37 PM
