Guess My Flywheel HP and TQ
Old Dec 10, 2009 | 08:48 PM
355_L98_GTA's Avatar
Car: 1984 TA
Engine: 355 Carb
Transmission: 700r4 Built 2200 stall
I'm going to be building a new motor in April and I mean brand new. It's gonna be a 383. I need to get an Idea of how much power I'm gonna have so i'm not dissappointed when its done. Here it is.....
Eagle 383 rotating assembly 6" rod with 11 to 1 pistons.
Procomp 190cc aluminum heads. I've heard good and bad about these.
Comp 8-305-8 cam and comp lifters.
Hedman 68460 lt headers.
TPIS ported intake
TPIS runners
Ported Plenum
58MM BBK throttle body
Adjustable Fuel pressure regulator
30# injectors
PCM for less Custom Chip
Ported and Desreened MAF
Power pulleys
All new Ignition
Custom Air Intake
Your guess is as good as mine.
Tired of getting outrun by stock LS1's
Old Dec 12, 2009 | 04:39 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Guess My Flywheel HP and TQ
375 Hp/475 ft lb Read this for some useful info:
http://www.compcams.com/Community/Ar...?ID=1737510521
Old Dec 13, 2009 | 09:37 AM
3rdgengmachine's Avatar
Car: 87 iroc z
Engine: 358 tpi
Transmission: 700r4 with transpack
Axle/Gears: 3.42 with powertrax
I also am building a 383 for my tpi only im going with the comp XFI 560/555 or 576/570 I havent made my mind up yet on which cam probly the smaller. And a set of the 1041 AFR heads. Also I was told at my machine shop its better to go with the 5.7 rods and get different pistons. I would like mor input on that Im going to search and start a new thread on that.I already have the headers roller rockers and fresh 40 over engine MSD and lots of other add ons. My only concern is if it will be wort it and if I will tell a big enough differenc to justify the $2500 i have to spend on the heads cam and new lifters and crank. Also I am going to start doing my own eproms and I hope someone has a good starting point for a 383 tpi motor.
Old Dec 13, 2009 | 12:45 PM
Car: 1984 TA
Engine: 355 Carb
My whole build is gonna cost me $4,000. I just want a 12 second daily driver. I plan on doing suspension work too. I'm going to use all spohn parts.
Old Dec 13, 2009 | 02:31 PM
Car: 87 iroc z
Engine: 358 tpi
thats not bad im going to have 200 in just heads, cam and lifters. How come your useing 6 inch rods insted of 383 pistons?
Old Dec 14, 2009 | 08:26 PM
Car: 1984 TA
Engine: 355 Carb
I have been wondering about the AFR 195 heads myself. It's a little hard to justify the price but I've been looking around and they are definately the best flowing 23 degree head on the market for that kind of price. I don't really know why I decided to go with the six inch rod kit. It all comes balanced with a flywheel and balancer. They had the same kit and the only difference I saw was the rod being longer which makes it heavier. Then I read that the piston is lighter with a six inch rod. After I get the 383 in there I'm gonna take out the 3.73's and put in 3.42's.
Old Dec 14, 2009 | 08:47 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
300 wheel hp with a mail in tune and tpi topping it max... probably 400ft lb though
Old Dec 14, 2009 | 09:53 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
The big reason for a long rod is to keep the piston at TDC longer, promoting a better burn... Bad thing is when the piston pin iterferes with the oil ring--not a problem on drag engines, but not real sure how they'll last on the street... I run a zero gap second ring and low tension oil ring, but again in a drag engine. Over 100 passes on it this summer, and still less then 4% leakdown on the cylinders......
Old Dec 14, 2009 | 10:56 PM
Car: 1984 TA
Engine: 355 Carb
What do you think I can pull with the AFR 195's and a little bigger cam and a Stealth Ram on top.
Linson
Oct 24, 2025 02:00 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
