can i get 300+ horses from my 89 5.7 corvette motor
Old Dec 13, 2009 | 07:16 PM
supamand23's Avatar
Engine: 89 5.7 corvette motor
hello everyone im new here and i have a 89 5.7 corvette motor i have a camaro tpi setup the car currently has tbi but i am goin to switch it over im not trying to race or anything just want to get a little better gas mileage an nice power at least 300hp within a buget of 1500-2000 motor is all stock with stock aluminium l98 heads any help is nice
Old Dec 13, 2009 | 07:32 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: can i get 300+ horses from my 89 5.7 corvette motor
Yep, do full exhaust/headers, bolt on TPI stuff-- larger base/runners, 1.6 rockers, and good tune and its at or over 300hp
You can do that for way less than 2000 bucks
Old Dec 13, 2009 | 07:45 PM
supamand23's Avatar
ok how much would a tune be is that for the ecm or motor?
Old Dec 13, 2009 | 07:52 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
ecm, need to do a chip burn. Wont really need it, the car will run fine without it, but could pick up 10-15whp in a simple tune with timing adjustments in the mid range and dialing in the air fuel ratio with the new exhaust stuff.
Can get mail order for like 250 or take it to some place. You can get the equipment you need to do it yourself for around 200-250 depending on what you get, then you can burn as much as you want. Its not all that hard to learn, especially with MAF
Old Dec 13, 2009 | 08:12 PM
supamand23's Avatar
do you think i would need bigger injectors? wat about a bigger cam even more hp wat kind should i get?
Old Dec 13, 2009 | 08:55 PM
southbay08's Avatar
if you are going to run approx 300hp you are going to need 24lb injectors.
Old Dec 13, 2009 | 09:06 PM
supamand23's Avatar
well i want at least 300 horses but 350 would be nicer
Old Dec 14, 2009 | 06:46 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah get a set of new 24lb injectors. I think stocker 22 lbs will do the 300hp but anymore than that, i'd get 24's.
Old Dec 14, 2009 | 11:16 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
24 over 22? That hardly seems worth the effort.
Old Dec 14, 2009 | 01:09 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
It is in that you are getting fresh set of injectors with a more efficient spray pattern, but that depends on the injector design. Some spray patterns are more efficient than others
If the motor has good condition 22 lb injectors, by all means use them. If the power goes up to 350hp, then 24s would be better suited. But to get 350hp you will need a cam.
I had some of my stock injectors go bad at 150k miles and i believe they were all original by this point. But they can fail at anytime. its not a bad idea to replace them while everything is out
Old Dec 14, 2009 | 01:35 PM
southbay08's Avatar
If you are going to go with the 22lb injectors, then you should definitely get yourself a set of the bosch design lll's, 4 spray better fuel atomization, improved overall performance.
Old Dec 14, 2009 | 05:03 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Not going to get 350 Hp without opening engine up
My old setup
'89 Vette engine ( better "113" heads than your "128" ones )
Siamized base , SLP big tubes , fully ported plenum , ZZ4 cam, 1.5 roller rockers ,LT's with no cat ;retuned using stock injectors
310Hp
Old Dec 15, 2009 | 10:25 AM
Russ-So Cal's Avatar
I see you are in San Mateo, Ca. You will need to plumb a Vette style egr to get your car to pass smog. The Vette aluminum heads don't have egr passages, so G.M. put a tube in for Vettes that goes from the exhaust directly to the intake. The steel L98 heads have a passage cast into the heads to route the exhaust for egr through the heads to the intake.
Old Dec 15, 2009 | 10:42 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
You might get away with the 22s if you install an adjustable fuel pressure regulator (AFPR). These AFPRs install onto the fuel rail in the engine bay, and are an easy way to do some fine tuning. The factory fuel presure should be around 43.5 psi. I have run my injectors as high as 54 psi. A 22#/hr injector at 54 psi will flow about 24.5#/hr. No matter if you go with the 22s or step up to 24s, I would always install an AFPR. They are not very expensive.
Old Dec 15, 2009 | 11:03 AM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
I would run the 24# for sure. Also, a quick chip tune wouldn't hurt, you can get decent power from a chip burn. PCMforLESS.com does excellent work and is inexpensive. The motor will run great without a tune, but that little extra power helps. I agree with above on rest. Headers, runners, bigger intake, 1.6 rockers, probably a good muffler as well. Should not be hard to hit 300hp.
Old Dec 18, 2009 | 12:32 PM
supamand23's Avatar
thanks for all the help guys
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
italiano67
Dec 11, 2016 09:21 AM
pimprs
Aug 24, 2015 11:20 PM
jharrison5
Aug 19, 2015 05:53 PM
