fuel pump isnt working?!
Old Dec 16, 2009 | 06:12 PM
mesterz2889's Avatar
ok so i swapped in a 4bolt 350 out of a 90s pickup. i put my tpi intake on it and all the wiring (i think) is back where its supposed to be and now my fuel pump isnt turning on when i turn my key to the on position. i spliced a power wire to the fuel pump wires and it does turn on. im just wondering what all needs to be in order for the fuel pump to turn on. and no the fuse isnt blown. this is driving me crazy, help please!
Old Dec 16, 2009 | 07:23 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
Re: fuel pump isnt working?!
Apply 12 volts to the "G" terminal on the aldl port. If the pump kicks on you have a faulty fuel pump relay.
By jumping this port it will bypass the relay.
Old Dec 17, 2009 | 04:51 PM
Ok I will have to try that. I'm just hoping its not my ecm. Thanks
Old Dec 27, 2009 | 10:47 AM
Ok I jumped 12 volts to the G port and the fuel pump turned on so I got a new relay and it still won't fire! Am I missing something? I got another ECM and still nothing. Could it be the oil pressure switch?
Old Dec 27, 2009 | 11:00 AM
I don't know if this helps but when I jumped the fuel pump it just kept going instead of shutting off when the fuel rail was primed. ?
Again I don't know if this matters but the knock sensor isnt plugged either
Old Dec 27, 2009 | 01:33 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
I might be mistaken but on some of them if the oil pressure sensor is faulty it may act like a fuel cutoff as well. If that doesnt do the trick it would be time to start tracing some wires. If you apply 12 volts to the G terminal it will keep running until you remove the power source.
Old Dec 27, 2009 | 02:10 PM
I'm off to autozone!
Old Jan 11, 2010 | 05:20 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Did the oil pressure sensor solve the problem?
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
mustangman65_79
Apr 14, 2017 05:37 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
