help! no start
Car: 88 IROC
Engine: 305TPI
help! no start
tearing down 88 iroc for a paint job now it wont' start. the fuel pumps not kickin on. all the fuses are good(double checked) and there is NO continueous power to the fuel pump relay. i jumped the pump at the back of the car and it works fine, is this a computer related issue?..i also tried the jumping at the aldl port..that didnt work at all any ideas?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: help! no start
The relay , oil pressure switch and ALDL terminal all put power through the fuse to the pump .You may have a broken wire somewhere.
I would check for continuity from the fuse terminal to the
ALDL terminal
relay terminal
and to the pump
92camaroJoe
Aug 13, 2015 06:07 AM
