RAM AIR INDUC. VS COLD AIR INTAKE
Old Dec 19, 2009 | 06:40 PM
Fdeleonz28's Avatar
Car: 1986 Iroc-Z
Engine: 5.0 H.O.
I have a lb9 iroc..i made an ram air induction for the nose of my car with ac vents.. it does pretty good.. i fell more of a pull on the top end then before.. but by making a cold air intake will it be better over all?
Old Dec 19, 2009 | 09:15 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
Re: RAM AIR INDUC. VS COLD AIR INTAKE
Any pics? Good idea using ac tubing. Hawks sells premade sheet metal version for $100. I know people have tried similar approach. Curious to see how you did it.
Did you cut off air baffles on lid? That by itself will allow lid to flow 50cfm or 10% more. I removed baffles on my stock 350 and felt a difference up top too. Haven't messed around with fog light ducts yet. What you are doing is making a cold air intake. From what I have read, ram air effect does not exist for cars. Car speeds would need to be very high for ram air or "supercharging" effect of intake to occur. You could rework air lid to make it taller. Would free up some more air by removing tight spot where it necks down.
Not sure if you saw these posts.
https://www.thirdgen.org/forums/fabr...i-air-lid.html
https://www.thirdgen.org/forums/tpi/...airfilter.html
https://www.thirdgen.org/forums/tpi/...pi-camaro.html
Old Dec 19, 2009 | 09:24 PM
Stephen's Avatar
Car: 87 GTA
Ram Air Induction is always cold air.
But Cold Air Induction doesn't automatically = ram air.
Old Dec 19, 2009 | 11:53 PM
Fdeleonz28's Avatar
Car: 1986 Iroc-Z
Engine: 5.0 H.O.
thanks for those post..they Really helped alot.. i might do that to my lid aswell.. tha ac vents work jus *** well and i used ac tape u hold em in place it dont look too bad i jus need to spray paint the vents black and put some gaurds..ill put some pix up soon
Old Dec 21, 2009 | 05:55 PM
ssean92's Avatar
Car: sold
I made my RAM AIR II hood functional and LOVE it, air inlet temps dropped ALLLLOT
Old Dec 24, 2009 | 05:16 PM
Fdeleonz28's Avatar
Car: 1986 Iroc-Z
Engine: 5.0 H.O.
here are the pix from my ac vent ram air lol
Old Dec 24, 2009 | 05:43 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
ya..it's a fun fix..I did Mine back in 93/94 on My 92 Z28.
forgive the Dust.from 7 years of sitting locked up
rivets and sheet alumn.. the Lower air box is still 1 piece.
and can be removed like the the OEM box.
Old Dec 26, 2009 | 12:05 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Thanks for posting some pics. Good idea using ac duct tubes. I' thinking about modifying my lower base to accept round cone filters that would site down a bit in ducting. I've read that K&N filters support around 4-5hp per square in of filter area. From some rough calcs I think stock filters will support 240 hp. Not sure if this mod will made a big difference as people are making lots of power from stock filter setup. I have an extra lid so I figure might as well try it out. Air intake design almost seems to have been an afterthought by GM when you see how they pieced everything together.
Old Dec 27, 2009 | 09:59 PM
msl93's Avatar
Car: 84 Z28
Engine: LT1 swap in progress
I've been looking for something like this where I could still use the stock filter setup but I think I might try and use a scoop somewhere with it, do you think their will be any problems with rain getting forced through?
Old Dec 27, 2009 | 11:55 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Hawks has a couple of nice setups
http://www.hawksthirdgenparts.com/ca...mairboxes.aspx
http://www.hawksthirdgenparts.com/ca...icarsonly.aspx
Old Dec 28, 2009 | 10:33 AM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
msl93, rain could be a concern in heavy storms. Even if filters got wet you could dry them out afterwords. KN& filters seem very sturdy, doubt water would get through. Every stock paper filter I've pulled on cars seems warped probably from rain.
Old Dec 28, 2009 | 10:48 AM
Jeffs82TA's Avatar
The only ram air systems do a thing is a supercharger or turbo! The rest are gymics that do nothing!
Old Dec 28, 2009 | 11:06 AM
ls six's Avatar
Holy crappy grammar and spelling batman!
At the very least a "ram air" setup works as a good cold air setup.
The ram air effect is impossible to detect on a dyno obviously and the butt dyno often tells you what you want to hear but there are still reams and reams of data that show that a real ram air intake improves trap speed and ET, improves average speed on the oval and road course, makes a significant differance at Bonneville and golden state type events.
Data from the OE's and from racing teams show the effect to be real and significant also.
As a rule of thumb the effect is not noticable until about 60 mph, but that ofcourse depends on the system the car and several other variables.
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
