installing a new cam in my tpi and need some advice
Old Jan 9, 2010 | 07:25 PM
ruben0227jr's Avatar
hi i have a 1988 iroc with a hyd roller 96-2000 vortec engine its a tpi set up with a tpis big mouth intake along with slp runner and a matching ported plenuem to go with it (52mm throttle body) I recently bought a gm cam that was used on their ram jet 350 would this be a good match with what i got? also the heads are oem that came with the iroc (cast iron) with steel roller tip rockers 1.5 - 3/8 exhuast system is a 3 inch with super com hooker headers.
Cam Specs:
Description- Hydraulic Roller Design
Advertised Duration- 288(Int) / 308(Exh)
Duration @ .050"- 196(Int) / 206(Exh)
Max Valve Lift W/ 1.5 Ratio Rocker- .431(Int) / .451(Exh)
Lobe Centerline- 109
Old Jan 15, 2010 | 11:17 AM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: installing a new cam in my tpi and need some advise
If thoes specs are correct that cam is pretty lazy and i think you could do a good bit better. The lift duration at .050 dosnt look too bad especially since your running a TPI with factory heads but its the ramp rate the i think is pretty terrible. The ramp rate is basically how quickly the valves open and faster is better for more area under the curve. Typically you see something like a 50 degree difference between the advertised and at .050 duration where as that cam is roughly 100 degrees lol. This means it has a very slow ramp rate to the point that dosnt even look right. Just my take on it though.
Old Jan 15, 2010 | 12:18 PM
well thanks for your advise good thing i havent installed the cam yet the reason i got this cam was cause i wanted good gas milage and i dident really want to mess with reprograming the computer do you have any advise on cam specs that would give me good gas milage at the same time giving me better performance this car will be a daily driver.
Old Jan 15, 2010 | 12:48 PM
Glenno's Avatar
Car: 1990 Jeep YJ
Engine: 70's 350 w/87 Z TPI-MAP Conversion
Transmission: Muncie SM 465 Granny Low 1st
Axle/Gears: 4:10 Gears in both axles
Call any Cam Company and the tech people will gather your specifics and help you to get a cam that will work where and how you want it to work. Good luck.
Old Jan 15, 2010 | 01:43 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
thats a pretty tight lsa, might be fun to tune.
Old Jan 16, 2010 | 04:14 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Welcome to the board.
The cam is pretty small for the engine.
However, since you are using the stock heads, you are limited by the spring lift of the original head. I belive the springs on the stock heads are good for a .480 max lift.
Even a used stock LT1 cam would be better choice (cost about $20)....until you upgrade the heads.
LT1 cam - 201/208 447/459 116
You could use a aftermarket cam and modify the heads with bigger springs and screw in studs.
Old Jan 16, 2010 | 06:27 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
LT1 cam - 201/208 447/459 116.
One right here $20
http://www.camaroz28.com/forums/showthread.php?t=732221
Old Jan 16, 2010 | 08:27 AM
Car: 89 IROC
Good price.
...just send a reply on the roller rockers....thanks!!
Old Jan 16, 2010 | 09:44 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
a gm hot cam will go well with that highflow tpi its 218/228 .492 .492 with 1.5 rockers on a 112lsa... thats what im running in my tpi with modified stock heads and im impressed with the results
Old Jan 19, 2010 | 04:54 PM
well i will look into the lt1 cam but i just dont get it this cam is an improvment over stock ant it? i look into this cam and all i hear is good reviews hes one by a senior member on another forum " should gain about 35 hp at 4500 rpm (peak) and 50 hp at 5000 !! With no torque loss anywhere !!! " to me thats pretty good since gas milage is my goal. well just want to know what yall heard about this cam (cam number gm14097395) thanks
Old Jan 19, 2010 | 10:06 PM
Car: 89 IROC
35 hp increase with those cam specs is unrealistic
LT1 cam swap over stock might give you 15-20 hp. No more.
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
anesthes
Mar 10, 2016 10:35 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
