MAF to MAP vacuum hose connection question?
Old Jan 15, 2010 | 12:12 PM
Glenno's Avatar
Car: 1990 Jeep YJ
Engine: 70's 350 w/87 Z TPI-MAP Conversion
Transmission: Muncie SM 465 Granny Low 1st
Axle/Gears: 4:10 Gears in both axles
I've been searching and can't seem to find a good picture or diagram of where the vacuum hose should connect to the plenum. I've converted from a MAF system to a MAP system and need to run vacuum hose to the MAP sensor from the plenum. Do I need to tap a hole and install a fitting or use a T of some sort? A picture would be great but any information that may help would be good too.
Old Jan 15, 2010 | 01:50 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: MAF to MAP vacuum hose connection question?
there are 2 vac ports on the pass side of the plenum one for the pressure regulator and the larger one is for the hvac. I would cut a t into the hvac line as close to the plenum as possible.
Old Jan 15, 2010 | 04:16 PM
Glenno's Avatar
Car: 1990 Jeep YJ
I know exactly which port you're talking about and I will T it somehow. What I don't know is what hvac means? Thanks for your help.
Old Jan 15, 2010 | 04:23 PM
hvac = heating ventilation air conditioning, that port supplies vaccuum to the heater controls
Old Jan 15, 2010 | 04:47 PM
Glenno's Avatar
Car: 1990 Jeep YJ
I don't think my Jeep has the hvac needed like in the GM cars? I could just connect the MAP vac to it and forget about it? Thanks again.
Old Apr 24, 2010 | 12:22 AM
S-chargedIroc's Avatar
Car: 1987 IROC Z
Engine: L98 350
Glad you found a solution. On the same note if anyone can please tell me how to convert my MAF to MAP on my vehicle i would appreciate it. I just purchased a FAST XFI ECU. Fortunately it came with the MAP sensor in the kit. All i need to do install it somehow...I own a 1987 IROC TPI (Supercharged 350)
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
mdtoren
Aug 23, 2015 12:52 PM
redmaroz
Aug 16, 2015 11:40 PM
mdtoren
Aug 16, 2015 05:45 PM
