Air Intake Modifications and MAF
Old Jan 21, 2010 | 01:35 AM
Three Arches's Avatar
Car: 1985 Trans Am
Transmission: 700-R4
I have an 85 Trans Am with the 305 TPI powerplant. Wasnt too impressed with the air intake, so am doing some mods. First, removing the thin plastic box and replacing with air hose. That is behind the MAF, so no problem. However, the next mods planned are in front of the MAF. I will either build a whole new CAI, or modify the stock filter canister by cutting holes in the bottom to increase cold air flow. Here is my question: At what point does the MAF need to be recalibrated or replaced? Will increasing air flow while still using the existing filter require it? Or, going beyond that to build a whole new CAI, K & N or similar? This is probably a common question, but I couldnt seem to find specifics on the Board.
Dave
Old Jan 21, 2010 | 06:07 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: Air Intake Modifications and MAF
Take baffles out of box, cut holes in bottom of box, go to K &N filters. As far as the MAF, very carefully cut the screen out of it, very restrictive.....
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Dec 6, 2015 11:25 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
