OEM Fuel Injectors?
Old Jan 21, 2010 | 04:21 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
OEM Fuel Injectors?
Has anyone ever seen this type of Fuel Injector? Im not sure if it's stock or aftermarket. The casting # is on the side. So can anyone help me out please? Thanks Guyz.
Old Jan 21, 2010 | 04:37 PM
Twin_Turbo's Avatar
Re: OEM Fuel Injectors?
Looks like rochesters, see if you can identify the #s here
http://www.juscuzmotorsports.com/injector.html
Old Jan 21, 2010 | 04:58 PM
Just scanned over and over agian and I couldn't match any numbers. Thanks for the help though Twin_Turbo.
Old Jan 21, 2010 | 05:04 PM
Twin_Turbo's Avatar
What is the number on them?
Old Jan 21, 2010 | 05:42 PM
it looks like
5720D 780
or
57201 780
Old Jan 22, 2010 | 02:25 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
they could be either Bosch or Lucas injectors. both were used from 85 to 88.
they don't short out as bad as the Multecs, but are more prone to clogging.
if your having problems with them, a set of bosch 3s from southbay or FIC is a nice up grade.
Old Jan 22, 2010 | 08:43 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I don't have any idea as to what kind of injectors those are. But I will say you have mad photographic skills. Nice to see someone that knows how to use a digital camera.
Old Jan 22, 2010 | 08:46 PM
Thanks for the compliment man. It's not really the skill of taking the picture, It's quality is because of my wifes camera. She has a Kodak.
It's has 12 Mega Pixels so that's why the pic. is so clear. Specs. are found here http://www.digitalrev.com/en/Kodak-E...mera-2995.html
Old Jan 24, 2010 | 08:32 AM
southbay08's Avatar
Ok, have your answer.... they are Lucas injectors and they flow 17.9lb at 43.5psi. Great pic, obviously very helpful!!! If you are looking for replacements we can help you with some bosch lll's.
If you have any questions you can give us a call at 516-492-6504
www.southbayfuelinjectors.com
Old Jan 24, 2010 | 09:07 AM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
actually that injector is the factory OEM injector installed in 85-88 305 LB9's.. The GM part number is 10108480. The internet has the data as 17.9 at 43.5.. That is incorrect. The injector is 17.9 at 35psi and 19 at 43.5. Can't trust the internet. But you can trust GM assembly and spec sheets.
Old Jan 24, 2010 | 10:35 AM
southbay08's Avatar
If you enlarge the pic, you will see this exact number on the side of the injector....it is a lucas and this is what i came up with. Either way the difference between 17.9 (18.0) and 19lb is minimal.
5720D780 = 17.9lbs 43.5psi 3.0 bar---Chevy v8-5.0l
Old Jan 24, 2010 | 01:22 PM
irocuroc, and southbay08, Thanks guys. So the previous IROC owner just swapped over the 305 injectors to the 350 block. So Southbay, How much are a set of 8 22 LBS Bosch 3's?
Old Jan 24, 2010 | 01:32 PM
southbay08's Avatar
You are welcome,,,,,,the cost for a set of (8) 22lb bosch lll's is $160 we will give you free shipping. They will be a direct fit. If you are interested in purchasing from us we can offer them with the "double o-ring setup" or with our new design adapter. Either one will be a perfect fit. We also carry them in 19lb. If you have any questions give us a call at 516-492-6504
Old Jan 24, 2010 | 01:59 PM
rednekwizard's Avatar
Car: 1986 Z-28
Transmission: 700-R4
I have the same injectors in my 86 Z-28 and I think they originally came out of the 305 that was replaced in mine too, I am upgrading as soon as possible due to the fact of the resistance being 16.5- 16.8 on all of them when the book calls for 11-14.
Old Jan 24, 2010 | 02:57 PM
One more question. I what to get the best bang for my buck. How old are these injectors 22lbs Bosch lll's? I mean, where they at some point in their life ever malfuntioning and you guys repaired them?
Old Jan 24, 2010 | 04:01 PM
southbay08's Avatar
ABSOLUTELY NOT!!! We stand behind our products 100%. All of our injectors come with a 3 year warranty. When it comes to the bosch lll's i must tell you that we have NEVER had a complaint or a return to date!! Besides we flowtest everyone of our injectors so we are 100% confident that we are selling a quality product!
Old Jan 25, 2010 | 09:37 PM
PV9685's Avatar
Car: 89 Firebird Formula
Engine: 305 Vortec, Single-plane, 4 barrel
Transmission: T5, soon 700R4
Axle/Gears: 88 10 Bolt, Disc, Auburn, 3.23
Check a different book Sir.
Old Jan 26, 2010 | 12:50 AM
Sounds good. Let talk to my bro n law to see if he is going to get rid of his 22 lb injectors. If he is going to keep em, then you'll definetaly get a purchase from me. Thanks.
Old Jan 26, 2010 | 07:08 AM
southbay08's Avatar
No problem, we are here if you need us!
Old Jan 27, 2010 | 03:21 AM
t-topsavage's Avatar
Car: 1988 Camaro IROC-Z/28
Engine: L98 5.7L T.P.I, stroked 383
Transmission: turbo hydro-matic 700R4
Axle/Gears: Borg Warner 9 boltG80 2.77
southbay I have a 383 stoker and am planning on throwing in a weiand stealth ram intake,
http://www.summitracing.com/parts/WND-7540/?rtype=10
and holley fuel rails,
http://www.summitracing.com/parts/HLY-534-186/
what would be a good sized injector for good flow for this system? or you got anything in stock for good price that would be good to make this a legit setup? thanks much appreciated.
Old Jan 27, 2010 | 08:40 PM
Well, first you must decide what your looking for. You can buy any injector that will suit your needs. The issue that you will have is that you would have to reprogram the PROM Chip (burn) so that your ECM knows what kind of injectors are being utilized. Example, off the assembly line, A 86 IROC 305 has 19 LBS injectors while the 87 IROC 350 has 22 LBS injectors. So asking for advice is good, but keep in mind that you'll need to burn your PROM chip at a DYNO Shop if you decide to choose a different flow rate injector.
Old Jan 27, 2010 | 09:12 PM
DENN_SHAH's Avatar
Chevy, if the injectors your brother in law has are factory GM Bosch or Lucas, they would need to be cleaned. it would probably be cheaper just to replace them with the bosch 3s.
and if they are multec injectors, well i wouldn't waste time putting them in.
the multecs are that bad.
Old Jan 27, 2010 | 09:14 PM
southbay08's Avatar
so if you can give me an idea of the hp i will definitley be able to set you up with a set of injectors that will meet your needs.
Old Jan 27, 2010 | 09:18 PM
southbay08's Avatar
I agree Denn_Shah, You will be very happy with the bosch lll's
besides, i just posted a sale for the members of the forum ...use the promotional code: TG11 and get 10% off on most of our products and services!!
Old Jan 27, 2010 | 09:27 PM
Thanks guys for giving me some heads up. You know, my bro n law gave me 86 IROC Z as a wedding gift back in 2002. I already agreed to take his injectors. But to your suggestions, I'm considering on buying some new injectors. Im going to tell my bro n law to hold on to his just in case he needs them as a back up. My 19 LB'ers work good, but since I got a 350, I would love to feel it's true power. Agian thanks guys.
Old Jan 27, 2010 | 09:29 PM
So how much difference will I feel (power gains) if I were to replace my 19 lbs for the 22 lbs Bosch III's?
Old Jan 28, 2010 | 09:02 PM
DENN_SHAH's Avatar
its hard to say just how much of a difference you'll see. it depends how bad of condition your injectors are in. add in you have a 350 running on 305 injectors and im sure you will notice a nice change.
the last set of bosch 3s i put in were for a 91 vette that was towed in from another shop. the multecs it had were so bad, it was causing the car to be hard to start and it was undriveable. that was after the other shop had already replaced 2 injectors.
after i got the bosch 3s in, it fired right up and ran perfectly.
the owner said he couldn't remember it ever running that good.
Old Jan 28, 2010 | 09:21 PM
southbay08's Avatar
Due to the 4 spray pattern and the improvement in the fuel atomization, you should see an improvement in the overall performance with the bosch lll's....improved acceleration, idle, fuel consumption, etc.
Old Jan 28, 2010 | 10:06 PM
Nice. Im gonna get the Bosch III's. Guys, thanks for your suggestions and support. Im not considering and more, I'm going to get em as soon as I get my income tax money. Agian thanks guys.
Old Jan 28, 2010 | 10:19 PM
southbay08's Avatar
If you have any further questions or concerns please do not hesitate to give us a call!
Old Jan 28, 2010 | 10:26 PM
Will do!
Old Feb 5, 2010 | 10:09 AM
Car: 1986 Z-28
If your going through summitracing they have a complete mpfi stealth ram system with injectors and module for the tpi setup
Old Feb 6, 2010 | 02:29 AM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
I'm running a 87 version HO 350 crate with my original TPI setup off of my 305 with 19lbs injectors. I still have the the original ECU and the way I understand , the MAF meters the air flow and sends the data to the ECU and the timing cycle changes for the injectors (19lbs to stay open longer for 350 engine) is this true? I have to admit that the idle is a little rough, but I think that it is due to the fact that they have never been serviced in 25 years. I did change the knock sensor and the ESC for a 350 engine and I am thinking of going to the Bosch III's injectors. Do they make these in a 19lb injector?
Old Feb 6, 2010 | 12:54 PM
southbay08's Avatar
Yes, they do make the design lll's in 19lb and we carry them. I can set you up with a BBk fuel pressure regulator which is a stock replacement for tpi 85-92 and you can adjust the fuel pressure to what you need up to 60psi. If you need the 22's...which i think you do.. they flow 22lb at 43.5psi and if you need 19lb you can drop the pressure to 34psi . We will be happy to help you with whatever you need!
Old Feb 6, 2010 | 04:59 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
huh? do you sell the tan 19lb bosch 3? I tried running 22's at 34. They run ok but the bottom range is a little dirty. Unburned HC went up, we still have inspection here. I think they run better at higher pressure like 43 which the system was designed around. The BBK AFPR is ok for fine tuning your fuel system. It's not a good idea to use it to change injector size. The stock fuel system in our cars don't like higher pressure. The head pressure in the pump rises and will cause pump failure prematurely. To pull a pump out of an f body is the biggest PIA you have ever had. JMO
Old Feb 6, 2010 | 05:12 PM
I agree. I had to drop my tank 2 times in 1 month. 1. replaced damaged tank. 2. Replaced bad pump. It really sucked. Especially when trying to bolt the 2 straps back on.
Old Feb 6, 2010 | 05:28 PM
southbay08's Avatar
it sounded like you were leaning toward the 19lb injectors. For a 350 you should use the 22lb at 43.5psi. And yes, we sell the tan 19lb bosch design lll injectors.
Old Feb 7, 2010 | 11:09 AM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
Southbay08, a good friend of mine needs your help. WileECoyoteSr has a 91 Z-28 with the 5.7 350 TPI engine. He believes that he needs new injector for his ride. He's been looking on Ebay and needs to comfirm the Bosch III part #, and proper inj. sizefor his car. I think his size would be 22lb.
Could you please help us out?
Old Feb 7, 2010 | 11:16 AM
southbay08's Avatar
Hi, yes i just sent you and your friend a pm, he is definitely going to need the 22lb Bosch lll's for a 350 5.7 tpi.
He can also go to our website, but the part # is 0280155700.
Old Feb 7, 2010 | 11:28 AM
Car: 87 T-Top GTA
I think he was looking on Ebay and was getting 2 or 3 different part #'s and sizes for his car. He just needs someone to comfirm size and part #'s, and I must omit, its nice to have part #'s on here for future reference.
Thanks.
Old Feb 7, 2010 | 11:30 AM
Car: 87 T-Top GTA
Question: Does a 87 GTA w/5.7 TPI(my ride) use the same part # and size injector?
Old Feb 7, 2010 | 11:38 AM
  #42
southbay08's Avatar
yes they would,,, once again the part number is 0280155700 or 0280155710
22lbs @ 43.5psi. Just remember, if you purchase from ebay without our "new adapter" or 2nd oring on the bottom of the injector,,,you are going to have a fitment issue....they will be too short. Stock injectors from 1985-1992 are approx 1/8 to 1/4in longer than the bosch lll's.
Old Feb 7, 2010 | 12:20 PM
  #43
Car: 87 T-Top GTA
Well, I know where I'm going for new injectors when the time comes! Do you think that this part will discontinued any time soon?(1-2yrs)?
Old Feb 7, 2010 | 12:31 PM
  #44
southbay08's Avatar
just to clarify something....these injectors are reman's though they all come with a 3 year warranty. i sincerely HOPE NOT!
Old Feb 7, 2010 | 05:22 PM
  #45
85 ZXX's Avatar
Interesting, I will check you guys out for sure...As far as mid to WOT the 350 runs great with 19lb injectors. All of my A.I.R. and Cat converter was trashed by the Mechanic who put this engine in for my son a few years back. I am not sure if I can get a prom for my ECU 1226870 (160 baud)with TPI 22lbs FI with a 5 spd trans. Maybe a Corvette of the same year might work. My ECU's prom is for TPI 19lb FI with a 700R4 trans and TC lock-up converter. any ideas will help.
Old Feb 7, 2010 | 05:38 PM
  #46
Interesting, I will check you guys out for sure...As far as mid to WOT the 350 runs great with 19lb injectors. All of my A.I.R. and Cat converter was trashed by the Mechanic who put this engine in for my son a few years back. I am not sure if I can get a prom for my ECU 1226870 (160 baud) TPI 22lbs FI with a 5 spd trans. Maybe a Corvette of the same year might work. My ECU is for TPI 19lb FI with a 700R4 trans and TC lock-up converter. any ideas will help.
Need help with crossing PROM to a different ECM or vice-versa, follow this link. It'll tell you what you need to know about 305 to 350 conversion and what needs to be changed when swapping things around between the 2 TPI engines..... http://tpiparts.net/305_tpi_to_350_tpi_conversion
Old Feb 7, 2010 | 11:47 PM
  #47
85 ZXX's Avatar
Will check it out...In 85 you couldn't get a 5 speed with a 350 in a thrid gen due to the torque it put out. The 5 speed was not rated for that much torque says GM. (What about the Corvette?) anyway, to make my car right, I would need a prom for a TPI 350, 22lb inj, 5 speed manual trans. Thanks!!!
Old Feb 8, 2010 | 05:20 PM
  #48
jaybee's Avatar
Car: 88 IROC
Transmission: auto
I ordered a set of the Bosch IIIs from Southbay this past summer and put in my 350 IROC. First time I had ever replaced an injector. It wasnt that bad, good time to go through and clean the whole TPI system and polish it. I used the double oring set up and they are working fine.
Old Feb 8, 2010 | 10:45 PM
  #49
stampede52's Avatar
i bought a set of bosch lll's from southbay too. Great company with customer service second to none. Will definitely recommend them. Friends of mine have used them and they too were very happy. A++
Besides, they are TGO sponsors
Old Feb 11, 2010 | 05:54 PM
  #50
randyz91's Avatar
Car: 1991 z28
Engine: 5.7 tpi
Transmission: th700r4
I,also replaced my injectors with Bosch III's (22 lbs.) on my 1991 z 28, from South Bay, about a year ago. Great product, Great price, Great performance, Great company! Nuff said! Randy
