Finishing up the build, do you see problems?
Old Jan 23, 2010 | 07:53 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
Ok, here are the parts, Anything i need to know before I swing wrenches?
Rebuilt shortblock w/ std bore no decking
ZZ4 heads with screw in 3/8 studs
LPE 211/219 cam
crane energizer roller rockers 1.5 3/8 Non aligning
Steel guideplates from SUMMIT
http://www.summitracing.com/parts/SUM-G6450/
stock '89 L98 pushrods
Fel-pro 7733PT2 Head gaskets
I know about using either S/A without guides, and guide with non align type, but if I add the guides to the studs will the pushrod make up the difference in throw? I figure what 1/8-3/16 inch.
Do I need a longer pushrod for the thickness of this headgasket. How can I tell? Looking forward to lighting off next week. thanks
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
jharrison5
Aug 19, 2015 05:53 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
