Intake thread size. WHICH TAP IS THE RIGHT ONE?
Old Jan 30, 2010 | 03:01 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
So I want to chase the threads on my intake. I have mastercraft's 41 piece std tap and dye set. I was checking with one would work in them and I came to the conclusion that a 5/16"-18 NC works.
Am I right?
Old Jan 30, 2010 | 04:24 PM
Guest
Guest
Posts: n/a
Re: Intake thread size. WHICH TAP IS THE RIGHT ONE?
On the intake manifold itself? Those are all metric holes. 8mm ... by I think its 1.25
Old Jan 30, 2010 | 05:57 PM
Stangski09's Avatar
Oh really.. Ya, well when I use the 5/16"-18 nc some metal dust comes out, no strings though.. I just tried it out because I was unsure
Old Jan 30, 2010 | 08:55 PM
Drew's Avatar
5/16 is approximately the same diameter as 8mm, but if you fully tap the 8mm holes in your intake with a 5/16 tap, chances are neither bolt is going to hold ever again.
Madmax hit the nail on the head, they're 8mm 1.25.
Old Jan 31, 2010 | 01:01 AM
Stangski09's Avatar
Okay. Good thing I didnt go in even a quarter of an inch. Thanks guys! I'll be sure to go get a tap
db057
Sep 4, 2015 07:57 AM
masonta
Aug 31, 2015 10:14 PM
IrocZ'85
Aug 17, 2015 06:24 PM
86White_T/A305
Aug 17, 2015 12:16 AM
