Large, 1 blade throttlebody. Is there such a Throttlebody?
Old Jan 31, 2010 | 11:22 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Look what I found guyz. http://ncarboni.home.att.net/NCtpi.html
Is there a throttlebody that we can use on our TPI systems. We are familiar with the 58mm throttlebody, but is there one that has 1 blade, and that can fit in or 3rd Gens? If so, Were can I find one?
Old Jan 31, 2010 | 11:37 PM
Stephen's Avatar
Car: 87 GTA
Re: Large, 1 blade throttlebody. Is there such a Throttlebody?
Yes there are mono-blade throttle bodies. But you need a BIG engine before you ever need one. Otherwise, your just wasting your money.
Old Feb 1, 2010 | 02:45 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
http://www.azspeed-marine.com/hpefimothva.html
Do you need 1300 cfm?
Old Feb 1, 2010 | 08:11 AM
S10Wildside's Avatar
Here are electronic (drive by wire) TPI throttle bodies in 52m, 58mm, and Mono Blade. To use any of these throttle bodies, you must run an LS1 PCM, LS1 throttle control module, and mount an electronic pedal...in other words, not a quick bolt on.
If you're looking for a cable actuated monoblade throttle body, contact TPIS (http://www.tpis.com). They will advise you not to use one unless you are working with a 400+ ci engine.
Old Feb 1, 2010 | 08:54 PM
So then I'm better off just getting a 58 mm Hooley throttlebody then. I was just curious because Im planning to fabricate a ram air type intake by using the fog light ports in the grill area. I want to make my IROC breath better.
Old Feb 1, 2010 | 09:19 PM
Stephen's Avatar
Car: 87 GTA
Your better off with a stock TB until you build an engine that needs a bigger one. 58mm on a stock, or even mostly stock, TPI....Is just wasting your money.
Old Feb 2, 2010 | 07:07 AM
IROC-You's Avatar
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
spend the money on some heads, cam or better intake first.
Elephantismo
Feb 13, 2019 12:51 AM
MrPackstin
Oct 25, 2017 08:09 PM
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
Damon
Sep 26, 2015 04:29 PM
