piston to valve clearance
Old Feb 1, 2010 | 01:42 PM
Mirocz87's Avatar
Car: 1988 Formula
Transmission: t-5
Hello guys, im in need of cam advice. im planning on getting a cast iron set of assembled heads from summit. the specs are 64cc chamber, 200cc intake, 2.02 intake valve and 1.60 exhaust. the max lift for the springs on it are .560. im looking to get into the high 300's or low 400's RWH with the stock bottom end and a HSR setup... i know i know but i plan on building a 383 shortblock on the side for later on down the road.. why not do it now? long story. lol. i guess my question is how much lift can i get without having piston to valve clearance problems on a stock l98 bottom end with those heads.
Old Feb 1, 2010 | 11:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: piston to valve clearance
Spring and retainer-to-valveguide clearance is usually a problem long before piston-to-valve is with stock pistons.
Old Feb 2, 2010 | 07:35 AM
Mirocz87's Avatar
Car: 1988 Formula
Transmission: t-5
thats what i figured, and i found another build about exactly like i have planned and it runs fine so i think ill be good. thnx for the advise.
db057
Apr 28, 2019 07:45 AM
New2Chevy
Sep 28, 2015 12:35 AM
355tpipickup
Sep 13, 2015 11:35 PM
Nick McCardle
Sep 10, 2015 08:36 PM
