Questions about electrical/vacuum issues
Old Feb 5, 2010 | 12:44 PM
48jeepster's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Alright, so I just bought an '88 IROC that has a 350 swapped in place of a 305, and I'm a bit stumped on a few things..
First of all, can anyone identify these for me?
They run on the passenger's side of the TPI system and (for some reason) I found them just laying in between the runners.. I have a picture of where they come out of a harness towards the front of the motor, that I can provide if necessary.
Secondly, it appears as if I'm missing a relay of some sort:
It's at the DEAD CENTER of this picture.
And while I have you guys here, can anyone identify the hose that is in the far right of the above picture? The one sitting in front of the ignition wires, with the 90^ fitting on it. If you look closely enough, just at the edge of the picture, you can actually see where a hose snapped off..
Old Feb 5, 2010 | 01:07 PM
Kodfish's Avatar
Car: 1990 IROC
Engine: 5.7 TPI
Re: Questions about electrical/vacuum issues
the one with the 90* bend is your hvac vacuum hose. look at the diagram under the hood to see how it's suppose to be hooked up.
Old Feb 5, 2010 | 01:17 PM
48jeepster's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Thanks.
Old Feb 5, 2010 | 01:21 PM
upandcoming's Avatar
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
your wires go to and air divertor controller..it controls your air pump. that is supposed to be under it...here is what the controller looks like http://i271.photobucket.com/albums/j...y/100_0783.jpg I can not see the tube you are talking about in the pic, but I assume that it is also part of the smog stuff..can you get another pic of it..
Old Feb 5, 2010 | 01:24 PM
Car: 88gta
Engine: 357
oh the vac. hose..sorry let me run outside and look
Old Feb 5, 2010 | 01:59 PM
Car: 88gta
Engine: 357
ok here is what the air divertor looks like on the car...http://i271.photobucket.com/albums/j...ertoroncar.jpg ...and your vac.. goes to a check valve then t's..one goes to the pletnum and the other goes to the pass side http://i271.photobucket.com/albums/j...uy/vachose.jpg where it again t's and goes to the cruise contol vac ball and the cruise vac controller http://i271.photobucket.com/albums/j...01.jpg....hope that helps
Old Feb 5, 2010 | 02:02 PM
Car: 88gta
Engine: 357
http://i271.photobucket.com/albums/j...image001-1.jpg ...here is the las link again.. for some reason the last one didnt work
Old Feb 5, 2010 | 02:09 PM
48jeepster's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Haha thanks. So all of that was just for the vacuum line that I said was broken, correct? I also found it interesting that there's a canister at the front driver's side of the engine compartment with a rather long tube coiled around it, disconnected.
I looked at the diagrams in my Haynes manual, and the problem is that the car WAS a 305TPI that is now a 350TPI and the diagrams for the car don't match up.. cause my battery is on the passenger's side front, whereas that 'canister' is on the driver's side.. so I'm not sure which one is that 'fuel vapor canister' and which is my cruise control..
Old Feb 5, 2010 | 02:24 PM
Car: 88gta
Engine: 357
yep.. for cruise control..now for the canister..there should be a fuel line on the frame rail.. and the vacumn lines go to the throttlebody
Old Feb 5, 2010 | 02:34 PM
48jeepster's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Thanks man. Any idea about the electrical connectors?
Old Feb 6, 2010 | 02:09 PM
Car: 88gta
Engine: 357
they go to the air divertor..check my first reply... I have an extra one if you need it..
Old Feb 8, 2010 | 04:40 PM
48jeepster's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Thanks again for your help. Just to follow up, it appears as if the previous owner did away with the AIR system entirely, including the diverter you spoke of, and just left the connectors. Must have done something right, because there aren't any codes or anything.
With the charcoal canister-- are there any negatives to leaving it detached? I'm in Florida and don't have any emissions tests or anything.. Thanks.
Old Feb 8, 2010 | 07:30 PM
Car: 88gta
Engine: 357
It might be a little rougher on gas..but thats about it..that I know of..
Frozer!!!
Jan 19, 2024 04:55 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Bryan F
Aug 18, 2015 02:28 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
