Using 88 SBC "carbed engine" for TPI conversion?
Old Feb 6, 2010 | 05:46 PM
R3500's Avatar
I have a couple of low mileage 350 roller engines from 1988 Caprice (police) package cars (been stored)
They were equipped with carbs and 305 heads from the factory. Would like use one for a project to install a SD TPI setup.
My concern is with the cams...was there much cam spec difference between the carbed and TBI 350 in 1988? Are they (carbed engines) good candidates for a TPI swap?
thanks
Old Feb 8, 2010 | 02:29 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: Using 88 SBC "carbed engine" for TPI conversion?
i thought the carb was discontinued in '87, if your going to convert to tpi then get a tpi cam or aftermarket cam.
Old Feb 8, 2010 | 02:46 PM
R3500's Avatar
In the police caprice..they used the quadrajet for 87 & 88. (Mine is code CWA
vin 6)
Guess I'm trying to determine the difference (if any) among the 1988 Carb,TBI and TPI factory cams.
I have a couple of OEM center bolt head quadrajet intakes manifolds used on the 88 police caprice.
midge54
Dec 27, 2019 04:14 PM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
