88 Iroc L98 Auto
Car: 88Roc Flame Red Black/Gold Pkg
88 Iroc L98 Auto
Hello all...My iroc just died the other day and doesn't start anymore. I hear the fuel pump when I turn the ignition on but it just cranks. Any suggestions on diagnosis or what I can check ..? Thanks all.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 88 Iroc L98 Auto
Is there spark? Do you hear the fuel pump running for 2 seconds after you stop cranking?
Car: 88 IROC
Transmission: auto
Can be numerous issues, check for spark first. Also, had a recent problem on my 88, was running fine, then got to where it wouldnt start. Had plenty of spark. Could smell fresh gas but couldnt locate it. Thought the gas smell was from flooding. Kept checking and found where an injector o ring had busted and was blowing gas down the backside of the manifold so it was hard to see. Replaced it and it cranked and ran fine since.
Car: 1989 Firebird Formula
Engine: 5.7 LS1
Take off the ignition coil on the car take it to an advance auto parts near you, they should be able to test it. I work for the advance in pensacola, fl and we now this feature we we can test the coils and know what voltage each coil is suppost to be putting out. its an easy, and free start, unless you need a new one, and they are only like 20 bucks for the coil.
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
first you check if your getting any engines codes lol.. how was it running before..did it sounds or drive rough..need more info other than it just died.check engine light code will help us point you in a very good direction of what the ecm is doing or not.
if there are no codes then start checking the basics..gas..air and spark.pull a spark plug out and see if its soaked in gas..completly white..or black.
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I say its the ignition module. Do this, get an old spark plug and pull one of the boots off an installed s.plug, plug it to the extra s.plug and have someone crank the car while you hold the extra s.plug near or on the engine block (to be grounded). If you see spark then your problem isn't ignition. If you see no spark, then you have to track down one of the ignition components thats failed...
ps, don't hold the s.plug in your hand, hold the rubber part of the boot (so you don't get shocked)...
Car: 1987 Trans Am
it should still start up if it has maf problems, it'll just idle roughly... verify spark.
Car: 88 iroc-z
Engine: 5.7 tpi
i had the same problem and found it was the hall effect sensor in the ditributor. had a friend check it and sure enough not enough magnetics on the sensor to give enough spark.you can pick one from a junk yard for maybe 20 or so bucks. just to try but it happend to me
Engine: 350 5.7L TPI
This happens to me occasionally. I just spray Starting fluid in the throttle body, then run around to start it. I works every time. Try that. I don't know what that means, but someone gave me that suggestion one time.
mustangman65_79
Aug 11, 2015 03:17 PM
