Problem with fuel injectors
Old Feb 9, 2010 | 04:06 PM
topher1316's Avatar
Hey guys I have taken my 305 out of the car and am in the process of rebuilding it. I forgot to label the injector wires, so I have no clue which ones go to which injector. I'm hoping some one has some advice to help me.
Old Feb 9, 2010 | 04:17 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: Problem with fuel injectors
you should not have any problem here, these cars are batch-fire not sequential. In other words the ECM fire one side at a time,if you look at your fuse panel you will see 2 fuses for "inj" left side and right side.......
Old Feb 9, 2010 | 10:21 PM
topher1316's Avatar
So I can just plug them in, any order??
Old Feb 10, 2010 | 08:53 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Yes.
Old Feb 10, 2010 | 09:20 PM
Drew's Avatar
In theory and practice 90% of the time, the wires have such a set to them from being plugged in for so long, they'll pretty much fall into place. But as mentioned you can plug any of the injector plugs into any injector and it'll still run the same.
bryan623
Mar 22, 2021 06:43 PM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
