I NEED HELP....
Old Feb 9, 2010 | 09:16 PM
kohake85's Avatar
Car: 85 Camaro
Engine: 89 TPI
Axle/Gears: 2.77
I NEED HELP....
Ok, so here is what i am attempting to do, I have a 85 z28 with the carb. 5.0 and 5 speed. I have currently dropped and 350 tpi out of an 89 iroc. i took the whole engine harness with it and computer. But the c207 connector pinouts do not match up, i was wondering if anyone had done this before. I do work at a mechanic shop and have access to wiring diagrams. But i am pretty sure i'm gonna have to add some fuses and wires for the injectors and to run power to my fuel pump.......
Old Feb 17, 2010 | 01:24 AM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Re: I NEED HELP....
buddy of mine converted a 91 speed density harness to match the firewall dash connector of an 88 GTA. try and see if you can find the diagrams for the pinouts. i know factory service manuals have them
also, you'll have to do something about the VATS that the 89 ECM needs to run the car. without it, it will never start. could probably trick the ECM into thinking the VATS is there and working, do a search for VATS bypass.
LVZ2881
Nov 21, 2005 01:11 PM
reilly8282
Jan 14, 2003 09:26 PM
citgofan99
Jan 12, 2002 08:15 PM
