5.0 TPI Injector Swap to 5.7 TPI
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: 5.0 TPI Injector Swap to 5.7 TPI
When i converted my 305 TPI TA to 350 TPI i used the stock ECM and it ran perfect.. as long as you have the same ohm rating. now if you went to svo 24s i would recommend a chip mod..
Car: 89 iroc
Engine: l98
Transmission: tremec
the 5.0 are 19 the 5.7 needs 22's. you will run your duty cycle in the high 90's which can cause a failure which will result in engine damage. Call FIC and get a set of 22's I think they are like 125 for the design 2 and a few bucks more for the newer type 3 Bosch. Then get the prom configured by a competent tuner
Iroc8t8
May 4, 2026 08:09 PM
Sanjay
Aug 12, 2015 03:41 PM
