question about AIR delete
Old Feb 15, 2010 | 10:54 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
So I read everywhere here that removing the AIR system doesn't require any tuning to the ECM. Question I have is, if the AIR system pumps air into the exhaust upstream of the O2 sensor, requiring the ECM to be factory configured to read slightly lean (due to extra air pumped in) as normal, then why wouldn't removing the system cause the engine to actually run leaner?
Old Feb 15, 2010 | 11:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: question about AIR delete
The car is in open loop when the air is pumped into the manifolds. In closed loop the diverter valve directs the air downstream of the sensor.
Old Feb 15, 2010 | 11:31 PM
Stephen's Avatar
Car: 87 GTA
AIR delete only accomplishes a visual change. It won't affect performance in any way.
Old Feb 16, 2010 | 03:54 AM
Pat Hall's Avatar
I removed mine and it never even triggered any codes in the computer. You won't notice any difference in the way your car runs with or without the AIR system functioning. Removing it cleans up the engine bay quite a bit and it makes it way easier to change spark plugs without the tubes in the way.
Old Feb 16, 2010 | 12:29 PM
Krik's Avatar
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
You will gain 0.25 hp untill the car warms up. Looks cool.
(at least half of this post is not a lie)
Old Feb 16, 2010 | 03:17 PM
el_muerte's Avatar
Car: '87 Z-28
Ok, that makes sense. Thanks
Old Feb 16, 2010 | 05:23 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
Half of my system was gone when I got the car. Made sense to get rid of that crap anywho. No performance gain, big visual. Much easier to get around your engine too.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
drathaar907
Aug 6, 2015 04:20 PM
