TPI Injectors
Old Feb 23, 2010 | 12:47 PM
ZEXY's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: TPI 350
Transmission: Brog-warner 5 speed
Axle/Gears: Borg-Warner 9 bolt 3.45 posi
TPI Injectors
I bought this firebird forumla with a new engine and a rebuild trans the old owner said that it was a 305 car but it had a 350 put in it now ive heard that the 305 and the 350 cars had different injectors and different fuel pressures as well im new to the fuel injection im 18 and i was wondering how i could tell what the injectors are like 19s or 22s is what i was told would come on them?
Old Feb 23, 2010 | 05:54 PM
southbay08's Avatar
Re: TPI Injectors
The 305 should have the 19lb, and the 350 the 22lb injectors. Both are flowed at 43.5psi. If you are unsure of what is in the engine, try to get the part number off of the injector i can tell you what size they are.
Steve78LT
Feb 24, 2016 12:15 AM
stalkier
Dec 6, 2015 11:25 PM
Keith5
Aug 27, 2015 04:37 PM
Brcharrelson
Aug 26, 2015 07:47 PM
Sanjay
Aug 12, 2015 03:41 PM
