EEC Canister Issue
Old Feb 23, 2010 | 06:13 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
EEC Canister Issue
In my quest to migrate from the stock ECU to the EZ-EFI setup, I've run across an issue which I need help with. I have an 89 TPI Formula; my charcoal canister is not compatible with the new EZ setup, I'd keep it if I could however it is controlled by the stock ECU so I think it has to go.
I'm guessing the best option is to plug the line from the tank and install a vented gas cap (which i have). So...what do i plug the line with? I know whatever rubber has to be fuel-safe but I'm unaware if fuel-safe caps are available. Moreover, is this still a safe method to use?
Also, if you have a better option (other than stay with the stock ECU) please chime in.
Thank You.
Eric
Bubbajones_ya
Jul 6, 2024 08:32 PM
Vojtush31
Oct 11, 2015 01:07 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
