high idle and no deceleration or small amount
Old Feb 27, 2010 | 09:11 PM
irocz813's Avatar
Car: 1989 Chevy Camaro Iroc-Z
Engine: sb 350 with TPI
Axle/Gears: stock
hey i have tried to figure out this problem but have had no luck....if i start my car and drive it the idle its high around 2k when i get somewhere and go put it in park the idle rises to around 4k and i don't know why this is...also when i drive there is no deceleration when i let go of the pedal it just seems to be in cruise control...i have to tap the breaks to keep a constant speed...so i have no clue what the deal is so any help is appreciated
Old Mar 1, 2010 | 04:35 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: high idle and no deceleration or small amount
Throttle linkage sticking? Vacuum leak? bad IAC?
Jake_92RS
Jan 28, 2020 10:37 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
db057
Aug 22, 2015 08:17 PM
InfinityShade
Aug 22, 2015 08:00 PM
