Corvette base + F-body fuel rail = Leak?
Old Feb 28, 2010 | 03:09 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
I installed ZZ4 heads and cam on my 1991 roller L98 motor, so I threw on a Corvette TPI base and it bolts right up.
Problem is, it seems the factory F-Body rail sits too high on the base and does not allow the fuel injectors to seat properly and eventually a couple of them will start leaking (badly)..
How should I fix this problem?
I do not have a Corvette fuel rail (just got the bare base) and was told the inlets on the TPI Corvette rail were different anyways.
Old Feb 28, 2010 | 05:21 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Corvette base + F-body fuel rail = Leak?
Are you using factory injectors?
You may have to file the 4 rail mounting bosses down a little to get a tighter injector fit ?
Old Feb 28, 2010 | 05:37 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
24# blue tops
Old Mar 5, 2010 | 06:25 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
bump
Should I grind the manifold? Bore out the fuel rail?
Old Mar 5, 2010 | 07:10 PM
Drew's Avatar
Some fuel injectors (notably Ford injectors) are a bit shorter then stock TPI injectors. If that's the problem you're having, there are enough people that have worked around that problem that a search should give you the answer you need. I'm willing to bet it has nothing to do with the Corvette base.
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
wayshegoes
Aug 17, 2015 12:00 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
